Question about Refrigerators
Leaking water into the fridge on top shelf - Refrigerators
  • Refrigerators Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Aug 04, 2010
  • 1 more comment
  • pdoyle_licsw Sep 29, 2010
    How to remove the rear freezer panel? screws?
  • Mike Smith
    Mike Smith Oct 01, 2010
    yes
  • pdoyle_licsw Oct 01, 2010
    thanks amillion! perfect solution, since you also include 'how to prevent'.
    can't wait to try it tomorrow; you have no idea how appreciative we are!
    pdoyle
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
Why is there water on top shelf in fridge
I would guess the fridge is not set level. A small amount of water is normally meant to condense and run down the back of the fridge and then evaporate outside the fridge.
If either the fridge is leaning forward slightly or if anything on the top shelf is touching the back of the fridge, then instead of running down the back of the fridge water may instead end up on the top shelf.
Assuming the fridge is still working in every other respect then this is what I would suspect.
Aug 25, 2014 | Max-Fridge Refrigerators
Fridge leaks on the inside
The drain line in the freezer is blocked. It drains the water away after the defrost cycle. You will need to post your model number for me to be of more help.
Mar 30, 2012 | Refrigerators
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Leaking water INTO fridge
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Jan 21, 2008 | Haier HTQ18JABRSS Top Freezer Refrigerator
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
