Question about Konica Minolta Office Equipment & Supplies
All the online help for the bizhub c350 error message 0500 says to use the small hole on the right of the control panel. My husband and I looked all over! and can't see one at all. Is there another option?
    Scholar:
  • 177 Answers
HI the best thing to do first is switch of the machine hold down the utility counter key while holding it down power back on the machine wait until the konica logo appears on the screen then take your finger of the utily counter button when you see trouble reset come on the screen press on it then it will say ok power off the machine wait ten seconds and power on the machine if the code goes away you age good to go however if the code comes back up you will need a technician trained to look at the machine as there will be issues with the fuser unit this is a dangerous unit that should in no way be messed with by any one than a trained certified engineer I HAVE WARNED YOU DONT IGNORE MY ADVISE
Posted on Apr 19, 2012
  • 1,110 Answers
Well that information is just wrong for the C350. The "reset button" or more acurately called the tech rep switch is located behind the large front door on the copier. Just to the right of the black Imaging Unit.
Look for the black Imaging Unit....the one with the K on it to more or less the lower right. Now just to the right of the Imaging Unit where the plastic cover turns to grey you will see a small rectangular hole with a small round hole just under it. That rectangular hole is where the switch is located. With the machine on just press the switch with a small non metallic object and the C0500 should reset and the machine will ask you to close the door. If the code comes back in around 15 seconds or so then you have a fuser failure that will have to be repaired.
Good Luck and Thank You for using Fixya
wheatlandsvc
Posted on Aug 04, 2010
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
Code bizhub c350
Mam,
Open the front door lay down on the floor and look up at the section that is slanted (close to hinge side of the front door) Fine the small hole with the machine on, fine a small non metalic stick and in-cert into the small hole touching the small switch which will re-set the machine for C-0500 codes. Do this once if the code comes back replace the fuser, DO NOT RE-SET again messing with FUSER can catch on fire will ruin a perfectly good day.
Dec 14, 2013 | Konica Minolta DiALTA Di200 Copier
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
Error code C-0500
On the control panel, Check the right side of the panel if there a hole, and press it w/ a paper clip, it will reset the code, if not. It need a new fuser unit
Apr 28, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c-0960 how can i reset it
C-0960 error code is for the bypass tray on a C350 copier. Make sure there is nothing binding up the tray lift mechanism. To reset open the front door, on the right side where the plastic starts to curve you will find a small hole, in that hole there will be a small button. Use a pen tip or a paper clip to press this button, this will reset the error. If the error returns there may be damage to the bypass lift system.
Apr 12, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
C350 bizhub image unit counter won't reset after changing
using a post:
So all settings are RESET.
thanks for krishmaqvan
Dec 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do you do a hard reset on a Bizhub c350? Thanks.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have a malfunction code on C350 which reads C-0400
this error code means the exposure lamp has failed and will have to be replaced. you can try to reset the error code but if it comes back the lamp will have to be replaced.
to reset the error:
1.open the front door with the machine left on
2. locate a small square hole inside the front door towards the bottom right.
3.insert a small object such as a small ball point pen to actuate a error reset switch the screen will indicate the front door is open when the switch is actuated.
Nov 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
129 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
