Question about Dell Inspiron 1501 Notebook
Keys zxcvm,. don't work. bn howeer still respond
How do I fix spacebar that is not registering/responding on my keyboard
you find out why its not working
did you spill something on the keypad
other than this is the space bar mounted correctly???
Mar 26, 2015 | Roccat Ryos MK Pro Mechanical Gaming...
Zxcvm buttons are not working.
use the system recovery manager coming with your computer or download from www8.hp.com and fix it.
God bless you
Jul 31, 2013 | HP Mini 1000 Netbook
My panasonic kx-fl501 fax message says please wait and the keys don't work
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Feb 08, 2012 | Panasonic KX-FL501 Plain Paper Laser Fax
Ti89 responds to resets but nothing else
If the calculator is several years old it may be showing its age.
There is a connection point between the keyboard and the display
that over time loses its efficiency. Try this: press a number key
and at the same time apply pressure with your thumb or index
finger to the region of the calculator just below the display.
If you press hard, the number may just show up in the display.
This is a test for the tightness (or electrical efficiency) of the
keyboard-to-display connections.
Another way to make this test is to twist the calculator while
you depress a number key.
Sometimes the effect is such that the keys on one side or the
other work, or don't work, and the keys in the middle don't work
or work okay. By twisting (don't break it!) the calculator body
while you press the keys will show the weakness of the
connector between the display and the keyboard.
This can be repaired by a good electronic technician if you
explain to him what I just told you.
Aug 29, 2011 | Texas Instruments TI-89 Calculator
I've got a IBM Wheelwriter 30 Series II and several keys won't activate print or movement such as zxcvm,.Line up, Lock and Right Shift keys. Everything else seems to work?
Over time, the keyboards on Wheelwriters tend to go bad. Unfortunately, the only solution is to replace the keyboard or have it rebuilt. If you can get it out, there are a few companies that will rebuild them. If you're able, I can refer a company.
Jan 08, 2011 | IBM Wheelwriter 30 Typewriter
My left and up arrow keys don't work
Try another keyboard. If the problem is fixed then get a new one. They are really cheap now a days.
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
Whenm I hit the bn i get bn, whenm i hit the nm i get nm - this is terribnle also whenm i type .com, i get a comma after the com,
I had the same problem, when I typed "b", the keyboard returned "bn", typed "n" and returned "nm". I fixed the problem by replacing a new batteries.
Hope it helps in your case.
Aug 10, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Battery changing problem
sounds like there's a dead cell in there. You'll need to replace the battery.
Jun 06, 2009 | JVC Lenmar BN-VF733U Equivalent Camcorder...
Canon ir 400s
Try cleaning the control panel and all the buttons/keys. If problem persists, try banging the keys individually. The control panel will not respond if any of the keys are stuck down.
Sep 15, 2007 | Toshiba e-Studio 205 Copier
Dell Inspiron 1501 Notebook Logo
373 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
