Question about Star Mirai DML-519N100 19 inch LCD Monitor
Monitor turns off immediately after you have connected
    Sergeant:
    Champion:
  • 301 Answers
Reinstall the driver , if not reintsall the all windows, if not try with another video card , buy it and plug in , if not your monitor is bad , repair or change
Posted on Aug 04, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
When starting computer screen immediately starts flashing colors. Nothing else. Then stops. And glitches randomly.
Turn off your pc and connect another monitor. If the external monitor works fine then the screen cable is damaged or your laptop's LCD needs replacement.
Jan 20, 2013 | Computers & Internet
My hanns g hg216d monitor goes to a black screen after a few seconds when I turn it on. The blue light remains on but the monitor is black. Tested with my computer and playstation 3 so it is definitely the...
This has NOTHING to do with the OS or the computer. This monitor has an HDMI connection and you can connect it to anything (cable TV, DVD Player, game console, etc.) and it still will go to a black screen after just a few seconds from powerin on.
Aug 14, 2011 | Computers & Internet
I have purchased a packard bell computer and lg flatron E2240 monitor but when I connect them up and turn on the monitor the monitor goes immediately into power saving mode. The monitor is connected to the...
if you are using a blue vga cable you need to make sure your computer recoginizes the lg monitor and that the input is correct. if you are using it as a dual screen you must enable duel screen mode in windows xp right click on desktop go to resolution and turn on the 2nd monitor same thing with win 7
Mar 14, 2011 | LG Computers & Internet
The monitor turns on and then turns off
Power supply will be the first place to check.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | IBM ThinkVision L171p (Black) 17" LCD...
I have a model Q7C4 when turned on it immediately turns off again even if not connected to the computer (ie power only)
Most modern monitors will not run if the signal from the computer is not present. If you can borrow another monitor, see if it will work. If ok, the problem is within your monitor. If the new one doesn't work either, then the problem is likely the video circuit in the computer--a bad video card if it's a desktop, but a bad circuit IC if it is a laptop.
Oct 08, 2009 | Computers & Internet
My Benq screen shuts down 10 seconds after switchung on
it may be overheat or check the cables it will properly connect or not(may be loose connection or damaged).
click this link for more info
Feb 22, 2009 | BenQ FP731 17" LCD Monitor
Monitor will not work
Your model number indicates the LCD is made by BenQ. This model is known for poor solder connection causing the inverter driver transistors to short, resulting in immediate shutdown if the inverter circuit. Disassembly and testing the transistors is the only solution I know.
Monitor Mike
Jan 02, 2009 | Computers & Internet
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
Hp laptop wont restart
please connect your laptop to external monitor.
if it works with external monitor, then the problem is with your laptop monitor driver.if that is the case, then re-install laptop monitor drivers.
if it doesn't work even with the external monitor, then re-install graphic card drivers.
Apr 05, 2008 | Computers & Internet
Star Mirai DML-519N100  19 inch LCD Monitor Logo
228 people viewed this question
Top Star Computers & Internet Experts
Abdul Mannan
Abdul Mannan
Marvin
Marvin
Are you a Star Computer and Internet Expert? Answer questions, earn points and help others
