Question about Baumatic B187 Stainless Steel Electric Single Oven
The oven tripped the main fuse switch to the house while on and when i restored power the clock on the oven came on but nothing else works no grill, oven, fan or lights ???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
You have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Posted on Aug 04, 2010
Testimonial: "Setting the clock worked a treat thanks for the advice "
2 Suggested Answers
SOURCE: Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Posted on Mar 31, 2010
Hi I have a 4year old Lamona 4601 double oven, the top oven/grill works fine but when I turn on fan oven it trips the power on the main house fuse board.
When the main breaker trips it indicates current is escaping from the circuit to ground.
If it is a micro-circuit breaker that trips it indicates the circuit is consuming too much current - a short circuit.
Either way the wiring or the oven elements have a fault and need attention.
Dec 20, 2017 | Ovens
MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
May 26, 2008 | Belling XOU252 Electric Single Oven
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Oven not heating
Mar 31, 2010 | Neff B1421 Electric Single Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Baumatic B187 Stainless Steel Electric Single Oven Logo
926 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
