I just acquired an Optoma EP771 (refurbished from Amazon). There is a persistent white vertical white light flickering band that I do not know how to get rid of, I have reset to defaults and I have also tried changing frequency and tracking but to no avail. I tried the projector with two different computers--one with vista and the other XP--same problem. Can you give me some advice?
    Brigadier General:
  • 6,966 Answers
with the indulgence of Ginko, may I offer alternatives to the cable replacement...
Try using another manner of injecting the PC's video signal into the projector other than what normally is used. If you are using now DVI, then use standard VGA, S-Video or even composite R-G-B or the plain yellow RCA Video IN if available from your PC and likewise with the Optoma EP771.
To my knowledge, white line(s) is a result of oscillation or signal bleedover of some sort in the video signal path (which includes the cable as Ginko has suggested). It is also possible of noise feeding back to the video processor/amplifier. Most can be corrected by additional shielding and/or putting capacitors in inputs or outputs pin (to the ground), but this has to be a case of winging it and requires a pretty good knowledge of RF and digital electronics components and circuitry.
If you are using a laptop (and even a desktop) try putting some distance between the PC and the projector. In some instances, using a common power strip with polarized plugs also helps. Some electronic lamps have also been known to cause some sort of interference as well as other electrical devices (including a genset).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
  • Louie  Role
    Louie Role Apr 27, 2008
    Have you tried lowering the Screen Refresh Rate of either PC (XP & Vista)? Additionally, you can perhaps lower likewise the Screen Resolution (just to verify that they are not causing the white lines).
    Being refurbished, the options are rather limited not unless Amazon provide some sort of warranty on the item. Perhaps you could also discuss your concern with them.
    Cheers and my compliments to Ginko.
  • 19,396 Answers
Try replacing the cable
  • Ginko
    Ginko Apr 26, 2008
    Often a defective cable can create lines, and similar phoenomena. Try first moving the cable and eventually replacing it.
    Check also if there are devices that may create inteference, for example power adapters very near to the cable.
    If it nsot the cable inspect the lens, and the inside of projector. A dirty lens or a defective lamp can create same problem.
    If it is none of the above, then it is a fault on the projector board , probably on input near side.
    If I was in your shoes, by the way, unless it is the cable, I would try returning the projector to seller.
    Suppose that is the lens, and it is one lens split in two , as soon as you disassemble the lens you will be blamed for the fault, best thing is contacting seller first
  • Ginko
    Ginko Apr 26, 2008
    Benimur may be right, but the fact is that if the projector is new, and for example works well only on Svideo and not on other inputs then it is faulty the same, and you won't be able to use full capabilities.
    You can also try troubleshooting online with Optoma, using
    Tech
    support online form.
    I think you will get same solutions, but it is always worth contacting manufacturer.
The background projects as yellow instead of white. Everything has a yellow tinge to it.
It sounds like one of the polarisers has failed, on experience they cost £300 each to replace, and there are 3 of them. I recently bought an NEC NP115 for just over £200, very good spec for the cost. It maybe worth investing in a new one.
Hope I was helpful for you.
Aug 08, 2011 | Optoma EP771 DLP Projector
My optoma ep771 projector, which i can't easily access right now since it's installed in our art gallery (very tall) ceiling. i think the bulb is out but i'm not sure. the light flashing situation is...
By what you have told me, the lamp possibly may have blown, so check if the product is still under warranty as you may be able to claim another lamp at no cost what-so-ever! It is however a definite code to tell you something is wrong! Hope this helps ;) ZKhan
Apr 20, 2011 | Optoma EP771 DLP Projector
How can i repair a optoma 706 lcd displaying white and black vertical lines?
FAULT: If lines are flickering with black and white and there is no data in line its mean the DLP unit is faulty.
SOLUTION: the only solution is this that you replace the DLP unit the DLP unit is electroniccomponent and not a repairable (as show in picture) good_help_19.jpg
Jan 24, 2011 | Office Equipment & Supplies
There is a line down right side of projected image, from top to bottom, different computers. Thanks Loren
I have a 2 inch white line down the middle of the screen from my Infocus DPL projector.
Can you help?
Paul.
Nov 29, 2010 | Optoma EP771 DLP Projector
Optoma ep771 displays the word menu
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Optoma EP771 DLP Projector
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
