Check the back wall or floor of the freezer section for frost. Check the
freezer( evaporator) fan to see if it is running. Check the condenser
coils( under the unit ) for blockage from dust. Check the condenser fan
(under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost
system and the freezer will start to warm eventually as well as the
fresh food section. If that is the problem you can check the defrost
terminator, defrost heater/s, and the defrost timer or adaptive defrost
control If used on your unit or the main control board if so equipped.
These things usually require dismantling the freezer and other areas of
the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the
refrigerator and letting it sit for at least 24 hours with BOTH DOORS
WIDE OPEN to allow the frost to melt completely but it will build up
again in 1-2 weeks and start the warming up again.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
heatman101
