Question about Siemens Gigaset 4000 Micro Cordless Expansion Handset
My sister has a Siemens Telephone Gigaset AS28H with 2 or more handsets and a base unit. Do you have an englis version of the manual so that she can see the list of 25 previously rec'd call, transfer the call to another handset if the battery is dying on the handset she is talking on, and allowing more than 1 person to talk on the handsets to a calling party? Siemens Telephone Gigaset AS28H English manuals
  • stephen_57 Aug 04, 2010
    It's unbelievable that a person has to go through such trouble to find an ENGLISH version of this phone!
CORDLESSGURU
  • 106 Answers
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Posted on Jun 16, 2008
SOURCE: Siemens Gigaset C1 telephone
Solution not found, but putting it down to the age of the apparatus.
Thank you for getting in touch.
Posted on Jul 24, 2008
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
confusedbrit
  • 38 Answers
SOURCE: I have Siemens C1 Gigaset
It should take any GAP compatible handset. Just follow the instructions in your seimens user guide to connect it.
Posted on Aug 20, 2008
SOURCE: Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
Posted on Mar 06, 2010
How do I fix my siemens landline phone?
well lightening does do bad things to telephones . that are always plugged in to electric and phone lines
Feb 25, 2015 | Siemens Gigaset A58H DECT 6.0 Digital...
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Handset won't work
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Want to unlock Siemens Dual Phone DP450
How To Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the phone from the Tesco Internet Phone service. This will enable the phone to be used with other Internet Telephone services. This follows the recent news that the Tesco Internet Phone service is to be ceased from April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450 defined and released by Gigaset Communications, the original supplier of the phone to Tesco. If this procedure is not followed exactly your phone might not work anymore. In this case Gigaset Communications cannot accept any warranty claims.
Unlock procedure
Your Phone should have the latest released Tesco software version, else this unlock procedure will not work.
On your handset:
BASE > SETTINGS > SOFTWARE UPDATE
Select and press OK Enter the system PIN (0000) and press OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the following service code. Please use the exact code as is described below, else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now "Eeprom" must be displayed)
Insert the following number sequence: 01778 06183 06191 Press OK to finish the programming. "Saved" must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail firmware version.
SETTING > BASE 94762001 (Now "Eeprom" must be displayed)
Now insert this number sequence: 04850 04351 04864 Press OK to finish the programming. "Saved" must be displayed on the Handset.
After this procedure you can upgrade your phone to use the latest retail firmware version.
SETTINGS > BASE > SOFTWARE UPGRADE
Please Note: The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone service, if you want to change this to set the default to the land line you need to change this in the web interface from your phone. How to do this, download the Gigaset S450 IP manual from the Gigaset web-site URL: http://gigaset.com/uk/en/cms/PageCustom ... nuals.html
Regards,
Smith Online
Apr 11, 2009 | Lands Phones
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Jun 15, 2008 | Lands Phones
My siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Dec 08, 2007 | Siemens Gigaset 4000 Phone
Answering machine
Unfortunately the 4010 model does not have a built in answering machine but does have features to work with your local telephone companies voice mail. If you want to keep your same phones and get a base with a built in answering machine you will need to replace your 4010 base with a 4015 base (up to three handsets), or a 4215 base (up to four handsets). But don't toss out your old base, you can use it to extend your range if you ever use a 4200 series handset that will allow you to register each handset to up to four seperate bases simultaneously to extend the range. You can buy the 4015 or 4215 base only and save yourself some money. You can google Siemens cordless repair or go to the Siemens website to find a few options.
Aug 12, 2007 | Siemens Gigaset 4010 Cordless Phone
Siemens Gigaset 4000 Micro Cordless Expansion Handset Logo
397 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
