Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
KENMORE WHISPERTONE 200. HOW DO YOU CHANGE THE BELT?
reddevil6
  • 1673 Answers
SOURCE: Kenmore Whispertone
The cover over the light, push in on the sides to release the tabs, then remove 2 screws. Using a screw driver, put it in the slot, one on each side, from the bottom, pry up to release the tabs, cover will come off and you can get to the belt and brush roll.
Posted on Jan 14, 2008
Kazong
  • 152 Answers
SOURCE: brush does not spin
definetley the belt if its the cannister vac like mine there is 2 screws on the bottom towards the back wheels take em out. on the side u have to pry open gently on the back side as well the top should come off and you should see a w plastic shroud around the roller there is a clip latch take the shroud off theres the belt
if not cannister vac on underneath the cover should have 4 or 5 little screws take em out under cover is the belt
hope that helps. gl
Posted on Jan 06, 2008
Vac Belts
  • 701 Answers
SOURCE: Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Posted on Oct 29, 2009
VacuumRepair
  • 438 Answers
SOURCE: KENMORE 23313 WHISPERTONE BROKEN BELT
Hi There,
Here's a link to a repair that I've already posted on Fixya on how to replace the belt on your Kenmore Whispertone. This should help you out greatly. If it doesn't and you still have questions, please feel free to use the Clarification Request form here on Fixya.com, and ask further questions. I'd be happy to do some further advanced diagnosing with you.
Thanks,
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Chris Jones
GoVacuum.com
Posted on Apr 13, 2010
Ironfist109
  • 3018 Answers
SOURCE: Hello! I was given a Kenmore Whispertone 200
  1. First you want to remove the hose from the canister itself.
  2. Now you will see a little "clip" of sorts on the inside of the handle (see red arrow on pic below)
  3. You just pull up on that grey clip and the canister opens up to reveal the bag.
Pic of bag exposed below
Now just lift that maroon piece up a bit to pull off the old and replace the new battery.
Regards, Tony
Posted on May 29, 2011
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
Hi There,
Thanks,
Chris Jones
GoVacuum.com
Apr 13, 2010 | Kenmore 23313 Whispertone Bagged Canister...
The beaters wont turn
You need to replace the belt. Here is the belt you need:
Kenmore 23313 Belt
Feb 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
HOW DO YOU CHANGE BELT CANT SEEM TO REMOVE BOTTOM TO GET TO IT KENMORE WISPERTONE 116
The top cover to the light lense pops off at the ends. When you get that cover off then you will see 2 screws that are by the swivel neck. Take those out and then the whole body top cover comes off. That will get you into the roller brush and belt area of this machine.
Dec 11, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Change the belt in my kenmore power-mate 120 amps...how to open it to get to where the belt is???
HELLO, JUST REPLACED THE BELT ON OUR'S. FIRST TAKE LITE LENSE OFF THERE WILL BE 2 SCREWS, REMOVE. THEN FLIP OVER POWER MITEON EACH SIDE PRY WITH 2 SCREW DRIVERS WHERE THE ARROWS ARE TO SEPERATE & THERE IT IS THE BELT. MIKE
Sep 13, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Whispertone
Sep 30, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
568 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
