Question about Garden
How to replace fuel filter. Cannot reach through fill cap.
  • 100 Answers
Try using wire bend hook on end
Posted on Aug 14, 2010
2003 Honda Civic LX code 1457 HELP
Error Code: P1457 Description - Evaporative Emissions Control System Leakage.
Causes:
- Fuel is filled with the engine start.
- Missing Fuel cap
- Wrong fuel filler cap is used
- Fuel filler cap seal is leaky.
- VSV Valve connector near air filter box is detached or wire broken.
- VSV Valve vacuum pipe near air filter box is detached.
Jun 01, 2015 | 2003 Honda Civic
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The evaporative system failed on emissions for my 87 Ford Ranger 2.9l engine, any suggestions what might be wrong
It can't be filled up because it leaks, or won't take anymore gas? Check the hose from the fuel filler to the tank for kinks or restrictions, if you have leaks, fill it up and trace the leak. Either problem will cause EVAP codes, hard starts, and cause vehicle to die.
Oct 03, 2012 | 1987 Ford Ranger
I need "step by step" instructions on how to replace the fuel filter on my 2001 Dodge Ram 3500 pickup. Thanks !
Here you go if it is a diesel:
A. FUEL FILTER REPLACEMENT:
The fuel filter is located inside of the fuel filter housing
1. Unscrew and remove fuel filter cap at top of fuel filter housing. To unscrew, attach tool to 6-sided hex center of cap. Do not loosen cap at outer edge. The fuel filter cap is designed to remove filter while pulling up on cap.
2. Remove O-ring from cap and discard.
3. The filter is retained to cap with little fingers. Carefully pry a couple of them off from old filter.
B. FUEL FILTER REPLACEMENT:
1. Thoroughly clean inside of filter housing, cap, etc. with clean diesel fuel
2. Fill filter housing (canister) with clean diesel fuel. NOTE: If you do not do this, you will have to manually bleed air out of system later. No fun.
3. Snap new fuel filter to bottom of cap.
4. Install new O-ring
5. Apply lihgt film of clean diesel oil to cap O-ring
6. Load filter/cap into housing.
7. Tighten cap to 25 ft. lbs. torque. Do NOT over-tighten.
Sep 03, 2010 | 2001 Dodge Ram 3500 Truck
How to change oil on a 2003 Kawasaki Vulcan 750 motorcycle? Where is the oil pan plug?
Firstly run your engine till you reach its normal running temp .The engine drain plug will be found under neath the engine normally at the lowest part .Warm oil drains out of the engine much more quickly that cold oil ..when all the oil stops dripping then remove the oil filter ,make sure that the sealing ring is removed ,take care the oil in the filter will be very hot .replace with your new filter make sure you do not cross thread the oil filter unit and any seals have been fitted . Refit your drain plug and fill up to the required level . start engine ,your oil level will drop because the oil filter will fill up and the new oil will be pumped around the engine. make sure that the engine level is topped up when all the oil has reached all the parts of the engine .Do not over fill the engine as this will cause unwanted pressure .and oil leaks .Remember to replace the oil filler cap and that its tight .
Mar 14, 2010 | 2003 kawasaki VN 750 Vulcan
Not getting gas, in tank filter seems to be plugged up. how do you replace it?
Reach through the fuel cap with a blunted hooked wire, check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. HTH
Lou
Oct 27, 2009 | Garden
I have a mcCulloch ms1436nav will go dead when giving the fuel
Check the fuel cap. Sounds like a vapor lock in the tank from an unvented cap or a blocked cap. If it runs with the cap off or loose, replace the cap.
Sep 30, 2009 | McCulloch Garden
Replace fuel line
You can cut the line, push the fuel filter and fuel line attached to it out where you fill it with gas. When you are ready to put new line in, cut the fuel line at an angle so you can push it in the hole. Keep pushing in until it comes out the fuel tank fill hole. Attach your new fuel filter to the line and pull it back until the fuel filter lays in the bottom of the tank. Then cut the line to length and put it on the carburetor. Take the other piece hook on the carburetor and put it back in the tank.
Sep 28, 2009 | Echo Garden
Mower engine cuts out at exactly 1/2 full tank of gas
When that happens loosen the fuel cap and see if it stays running. If this is a gravity feed system make sure you have the correct fuel filter on it,the clear paper filters can allow vapor lock to happen,put the small briggs and stratton filter in it,which has a small chamber and a stainless screen.Also make sure there is no excess fuel line that would cause a dip or a high spot for a vapor lock to occur.
Aug 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
