Question about Measuring Tools & Sensors
Need copy of instructions/operating manual for Calterm 66434 digital multimeter. I know that the company is no longer around just hoping someone has a good copy. Mine got legs and ran away.
  • 206 Answers
SOURCE: dont know how to use black spur mini digital
I understand your question.
My concern is trying to explain operation of a meter that will or can be used on live electrical could result in someone getting hurt.
Here's a few simple directions (assume this is a digital meter, if it is an analog (needle pointer) meter, then my instructions might be a bit different.
General rule: Most meters have multiple voltage selections. Always start at the highest voltage selection and if the reading is too small to accurately read, slowly choose lower settings until you reach a voltage selection that gives a proper reading.
General Safety: Never touch anything metal while working with electricity. Remove all jewelry (watches, rings, (yes, even that wedding band, your spouse would rather see you alive with all of your fingers), necklaces, piercings, etc.)
Wear rubber shoes, do not stand in water, if you are sweaty, dry off and cool off.
Old electrician trick of the trade to prevent shock is to always work with one hand behind your back or in your pocket. This prevents you from becoming part of the circuit. However, hard to take electrical measurements with one hand. Improvise.
Voltage: Use this to measure the voltage output of a circuit, includine outlets, batteries, etc.
AC Voltage (alternating currents)- This is the type of voltage you have at your wall outlets. Should place the meter at the highest setting, usually is 1500 or 600 volts. Place the metal tips of the probes on the individual contacts. Take care to never cause the probes, while in contact with the live circuit, to touch each other. If unsure if the circuit is AC or DC, start here. Then you can switch to DC. (Note: Most DC
DC Voltage (Direct Currents) : This is the voltage from batteries. Most battery voltages are 24 volts or lower. However, if you are working on a special circuit, perhaps a solar electrical panel or some other type of circuit for storing electrical power for a residential backup power source, or perhaps a Uninteruptible Power Supply (UPS) for a computer, you may see higher voltages.
Note: Even if you think you know the voltage, start at the highest setting: On analog meters, you must choose polarity (+ and -, red and black) correctly, or you could destroy the readout. However, if you were on the highest setting, the meter movement would likely try to go in the wrong direction, but the amplitude of the movement would be small enough to protect the meter.
Resistance, Ohms or Continuity (often marked by the Greek letter OMEGA, which stands for Ohms. Sorry, not sure hot to get the OMEGA letter on here) - CAUTION: Only use these settings when the taking measurements on a circuit that is not live, is not plugged in or powered by batteries. If unsure, use the voltage settings to test first, if any voltage present, cannot check the continuity. (And if you have voltage, likely there is some continuiity.) A discussion of how to use these measurements is beyond the scope of this discussion.
AMP readings: Danger, danger: Some meters have the ability to read amps. However, unless using a clamp on meter type to read, this is the most dangerous for the person and the meter. (I've blown up two meters this way. )
Basically, the meter becomes part of the circuit, and all of the electricity to power what you are testing must run through the meter. If the item being tested draws 12 amps, and you have a 10 amp meter (usually the highest amp setting on most non-commercial meters) smoke will be released by the meter and you can kiss it goodby. (Hopefull, you are still in a mode where you can pucker your lips and your hair is not also emitting the pungent odor of burnt hair.)
With a clamp on meter, this is not a problem, usually, as the meter never becomes part of the circuit.
Hopefully, this gives you a basic understanding without putting you at risk for getting hurt or killed. (Note, I have a degree in engineering, was trained by my dad from a young age to respect electricity and use meters, and I have blown up two meters though no major fires. )So, please be very careful when using a meter. Please.
I take no responsibility for any damage you do to yourself, your meter, or your home, car, etc.
Posted on Sep 08, 2009
  • 18 Answers
SOURCE: darrell ,testing 240v with adigitor q1563
Make sure it is switche to AC Volts. If it is a range multi meter, set the range to 240V.
If it is auto ranging, it should do it on its own as long as it is set to AC Volts.
AMPS kill, voltage doesn't. Still, be careful working around electricity.
Hope this helps. If not, contact me and I will give you my email address and you can send a digital pic of the meter and I can tell you how to use it.
Hope this helps!
Rob
Posted on Sep 22, 2009
Testimonial: "it was helpful, but i worked it out in the mean time with the help of my neighbour thanking you darrell"
SOURCE: Need a manual for a Wavetek DMM, digital multimeter model DM15XL
Here it is:
http://www.tequipment.net/pdf/Wavetek/5XL10XL15XL16XL_Manual_Rev_A.pdf
Posted on Oct 01, 2010
  • 185 Answers
SOURCE: Hi I need instruction manual for Mastech Digital
http://www.p-mastech.com/products/04_dm/ms8230b.html
go to the bottom of the page, click on the link for download manual.
Posted on Mar 14, 2011
  • 49 Answers
SOURCE: I need an instructions booklet for my hdm4400
most multi-meters have its generic functions resistance, potential, etc. your manual is for extra padding in the box it came in. but if you are in need of a multi-meter then your technical knowledge should far surpass the multi-meters manual.
Posted on Jun 11, 2011
Answering system
You may download a copy of the manual at http://cdn-media.vtechphones.com/ecp/documents/product_Product/110/UserManual/1202/cs6219_manual_i4.pdf
The CS6219 isn't an answering machine. If it indicates you have messages, then the messages are on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone or you don't answer at all. Please contact your telephone company for instructions on accessing their voicemail system.
Oct 07, 2013 | Vtech DECT 6.0 Cordless Phone with Digital...
Calterm 66458
If you aren't familiar with using a Multimeter, refer to your User Manual. It COULD be a personal danger. Have someone assist/explain the proper way to use the device.
May 22, 2013 | Computers & Internet
Need a manual for a Calterm 66420 multimeter
If a video tutorial would be of assistance to you, please CLICK HERE
May 07, 2012 | Cal-Term Measuring Tools & Sensors
Manual for Calterm 66420 volt meter
I have the Calterm 66420 and the manual. Will email you a PDF of the manual for free; just let me know where you want it sent. thx. aj
Jan 08, 2012 | Motorcycles
M92A DIGITAL MULTIMETER instruction manual
I have 'WORKZONE M92A' multimeter,
I have lost the operating instructions.
Where can I get a copy of the operating instructions. Please
Jan 03, 2012 | Measuring Tools & Sensors
Recently someone gave me a Vivi Cam 20 without operating instructions or software. Can you help with operating insturctions?
You can view, download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 25, 2011 | Vivitar ViviCam 20 Digital Camera
I dont now how the camera works.
You need to get user/ instruction manual copy of camera to know about its features and operational details.
Click Sony Support link to download instruction manual free copy that has all details about Sony DCR-PC115E camera, it will help you operate camera.
Thanks.
Jan 06, 2011 | Sony Handycam DCR-PC115E Mini DV Digital...
Dear Sirs, Can you kindly provide me with a copy of User Instruction Manual for your Draper Multimeter DMM11B. Kind regards, Dawn Jamieson
The manual for the DMM11B is at http://www.drapertools-online.com/products/manuals/78999ins.pdf
If this helps please leave feedback
Feb 05, 2010 | Draper Expert Digital Multimeter
Measuring Tools & Sensors Logo
255 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
