Question about Sony Ericsson XPERIA X10 Cell Phone
Gtalk is not logging out. 1st time logged in user is not getting logged out i.e by default it is connecting to the previous user.
  • 3 Answers
Please my small child put email adress on sony-ericsson x10.please help me to unlock it
Posted on Aug 04, 2010
Gmail will only default to original user. Need to login to secondary user (already set up on this PC)
You should be able to click your icon (of the logged in user) when in Gmail or G+. This should then add a button that says 'Add Account...' , or show alternate accounts previously logged in. Click the other account or the add account button and simply login to switch accounts.
Good luck :)
Oct 18, 2015 | Google Gmail
How to block people from useing your router
You can set up a password to access your wireless network. Please follow these steps in order to enable wireless security:
  1. First you must open any web browser on a computer connected to your network (I reccomend plugging in your computer directly to your router using an ethernet cable instead of using a wireless connection for this process.)
  2. In the URL bar type in the IP address of your router (most likely 192.168.1.1). If that is correct you will see a log in screen.
  3. At the log in screen input your user name and password for the router. If this is your first time configuring your router input the default user name and password (most likely "admin" for both.) If you are unsure of your user name and password you can find the defaults at this website: http://www.routerpasswords.com/. If the default does not work you may have to reset your router to factory default by depressing the reset button on the back of your router for 10 seconds (WARNING: this will reset all previously configured settings on your router.)
  4. Once you have logged in navigate to the Wireless or Security tab, depending on your router.
  5. Under security type select WPA2 Personal (some older wireless devices will not be compatible with this setting, if you have older devices use WEP)
  6. Create a passcode for your wireless network and select Save at the bottom of the screen. If you are currently on a wireless connection you will be kicked off so make sure you write the passcode down before you save.
Congratulations! Your wireless network is now secure and only people you have given the passcode to can access your wireless network.
Sep 17, 2012 | Linksys Wireless-G WRT54G Router
I have two user on my computer but on one i can get on the internet and on the other i cant it says change the proxy setting
every user created on the OS will have to have different settings.....
before making changes...get the foll info from your internet service provider
IP Address, Subnet mask, Default Gateway, DNS server address both primary and secondary
once that's available.....
you can use different settings in in WinXP as below....
Control panel / Network Connection /Local Area Conn /Right click / properties/ Internet Protocol TCP IP / Check Box / Propertis / in IP address use the IP address that's been assigned by your internet service provider
log in to first user accunt and make the settings....for....
use the info obtained from the service provider.....
....then
in the IP address filed use some thing similar like this..(check your internet service provider for that info).....the foll is only an example from my PC
say....192.168.1.2 for user ONE
log out....
shut down and restart PC
log in to second user accunt and make the settings....for all the above fileds....then
in the IP address filed use 192.168.1.4 for user TWO....(note the difference of the last filed of the IP address....2 vs 4)...every new user a/c the last field of IP address keeps changing
1st user ....say 192.168.1.2
2nd user .........192.168.1.4
3rd user ..........192.168.1.6
etc...
http://windows.microsoft.com/en-IN/windows-vista/Change-proxy-settings-in-Internet-Explorer
hope this helps
reg
Suresh
Apr 28, 2011 | Google Chrome
My emachine won't log on to any user
1st u find out the machine is connected to domain or personal machine
Jul 01, 2009 | E-Machines eMachines Desktop PC
Gtalk after login problem
in this installation some files may be correupt due to that clean lens in your pc and update gtalk
Apr 20, 2009 | Google Talk
I could not log in to Gtalkn
please, check out your internet settings for google in your office
or
you can contact the system administrator, whether the google option is disabled or any server related issue for your pc.
bye,
Jan 27, 2009 | Google Talk
Gtalk Error 1
that's a problem with software...
try downloading google talk again and install it... even then if you are getting the same problem... its a problem in the Operating system... some file must have corrupted... so re-install OS and install gtalk...
or simple way.. juz login to your gmail id... u have an internal gtalk available... in inbox itself.. hahaha..
Sep 17, 2008 | Google Talk
Bizhub C252 -- printer defaults not retaining account tracking passwords
when you create account codes they are assigned a number, are you sure you are not starting at the end? It should only erase the previous information if you turn account track on then off.
kevin.hayes@bt.konicaminolta.ca
Oct 26, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Activity log
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Status tab and then click Log to the left. This page displays the activity log for your wireless router. The buttons located above the log can be used to perform the below actions: First Page - View the first page of the log. Last Page - View the last page of the log. Previous - View the previous page of the log. Next - View the next page of the log. Clear - Clear (delete) the entire log. Log Settings - Configure advanced options for the activity log.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Sony Ericsson XPERIA X10 Cell Phone Logo
75 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
