Hi ,my lg 42pg3000 tv has just started playing up. The sound is fluctuating from 0-100 when remote is used (both lg and virgin remotes) . I have fitted new batteries to both ,also when menu is called up it just moves round all functions sound /picture setup etc. The stand by light is flashing green when this happens. Ive managed to stabilise the volume on the buttons on the front of the tv for time being.
SOURCE: LG 37LC7D remote doesn't work
Turns out there is a problem with certain LG models made in Mexico during May. Not only did the remote stop working, but the TV started shutting itself on and off randomly. Took it back and exchanged it for a Panasonic. Not putting up with that, LG.
Posted on Sep 24, 2007
javswr
  • 44 Answers
SOURCE: Phillips 20 inch flat tv
usually a blinking led points to your power supply! You will probably find some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). sometimes there is more then 1 thing wrong.
Posted on Feb 28, 2009
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
VinayT
  • 1884 Answers
SOURCE: Toshiba 50HP16 Plasma tv has
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
budmrtn
  • 11361 Answers
SOURCE: My Regza 42
Try unpluggung it for 30 minutes and try again. If it is still bad, the power supply will be the first place to check.
Posted on Nov 02, 2009
Testimonial: "Thanks. Tried & it's still happening. Also tried reseting to factory default, but did not make a difference. Will look @ p/s."
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
Dec 27, 2015 | Alcatel Cell Phones
Tiger Jumbo remote on LG tv and Virgin media
Set-up instructions are so much to type in here, and is not possible too. If you wish to get more details, check the sites linked here. It has set-up code list and set-up procedure to most popular remote controls. http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Brookstone 538744 Remote Control
LG 47lg50 white screen no buttons responding
A white screen with nothing else leads me to believe you have a problem with a t-con board or a signal board on that TV.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | LG 47LG50 47 in. LCD HDTV
Lost remote for lg 42PG3000 can the output be changed manually
buttons on the bottom of tv. its like a toggle. push in to get the symbols to pop up on tv...
Dec 31, 2011 | LG Televison & Video
Remote control signal
check battery contacts in remote..dirty,,loose,bat needs changing
Jul 07, 2010 | LG 42PJ350 42 in. TV
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
Lg remote codes
Programming u-verse remote for LG4270 (LCD 42inch) worked fine with code 1346.
This is a "Plasma" code according to U-Verse technical support, but was suggested with perfect result.
Jan 05, 2008 | Directed 434MHZ Remote Control
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
