Question about Dacor DMO24SS Microwave Oven
Sparks when micro turned on. it appears the pannel
Sparks when micro turned on. it appears the pannel on the roof of the inside is burned and damaged. Can I simply replace the pannel?
  • 24 Answers
Yes if you can find someone to supply it as a spare part. Clean any grease or debris from behind it too. Often there are little plastic rivets that hold it on. You might as well order them too. If it burnt too bad there will be a carbonisation on the panel too which must be cleaned off as it will attract the microwave energy.
Before ordering anything, remove the burnt panel and run the microwave with just a cup of water in it to make sure it still works fine.
Whatever you do, do not open up a microwave oven cabinet, they are very dangerous inside. If you cant remove the panel from within the cooking cavity then leave well alone and get an engineer to look at it.
Posted on Aug 04, 2010
H 5040 BM has sparking/flashing coming from grill connection inside top of oven whilst microwave is in use causing this connector to glow red
take it in for repair as the connection is shorting out from the micro waves
get a quote as most repairs are more than the replacement cost
Mar 22, 2016 | Miele Microwave Ovens
Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 18, 2010 | Samsung Microwave Ovens
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Sparks and lightning like flashes appear when the microwave is on. It is a Dacor 24''
If something like a knife, spoon or fork is in the micro, this usually happens. It could also be that the interior of the micro may be damaged due to rust. Check for open metal, cracks or paint missing on the inside of the microwave.
Oct 17, 2009 | Dacor Microwave Ovens
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Flashing inside micro when turned on after a few
Make sure the inside is clean of all grease and the paper like screen needs to be removed and cleaned also. If the screen is burned it needs to be replaced. You can find one at an appliance parts store.
Sep 03, 2009 | Microwave Ovens
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Sparks in oven
the burning is normally caused by a small particle of food getting stuck on the waveguide cover, this then carbonises and starts to arc. replacing cover should return oven to normal
Feb 22, 2009 | Sharp R-1480 Microwave Oven
Dacor DMO24SS Microwave Oven Logo
108 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
