Question about Watches
Cardinal quartz 2107 the watch band is to big for me. how do i make the watch band smaller
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Aug 04, 2010
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
I have a hublo big band stainless steel watch (replica) that is too big, how do I alter the size, I can't find anymore pin holes
It's best to take it to your local jeweler, they should be about to help you size the band, or if there is an onsite watchmaker there he should be able to make it smaller in a matter of mintues
Jun 17, 2011 | Watches
Got this watch for xmas, nice. the band is too big. how do i adjust the metal band?
u can have ur watch to the watch shop they may make it short fitting on ur hand
Jan 04, 2011 | Invicta 100 Meter Sport Diver Quartz...
I have a wonderful cardinal digital watch that I just love. I received this as a Christmas present from a dear friend. Unfortunately the large black rubber band has broken at the hole that I regularly use...
mcdevito75 Here, You may be able to find a replacement band on ebay, or look for a small watch repair shop in your area for a replacement or repair, the band may be able to be glued.
Jul 09, 2010 | LogoArt St. Louis Cardinals Wrist Watch
How do i make my watch smaller in size
mcdevito75 here, You can visit the Repair Service section here at fixya, bottom of this page once at repair and service type in watches. Depending on the band you may have to replace it with a smaller one to fit your wrist.
Jun 21, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Hi I have a quartz woman's watch that I bought at Big Lots store the other day.. the wristband is too big for me.. how do i shorthen it ? that band is metal...stretching whatever I call-- I need to remove...
Save your nerves and your money. Visit your nearest watch repair shop and ask to get links out. If you will try to do it yourself, you will loose your strap as you wont be able to put it back together. If you anyway decided to do it yourself, click on my profile and check out my solutions. I do explained all this tricky job to one customer about a year ago, so, you will definitely find it if you have enough patience to go through all my solutions. Rate me plz.
Mar 02, 2010 | Citizen Cortina Eco-Drive BM8194-50L Wrist...
Watch band to big, can i make it smaller?
Yes
Almost all watch bands can be made smaller
Jan 05, 2010 | Fossil Watches
Can the batteries be changed in Britain?
of course you can just pop into any jewellers or watch shop they will fit it for a small fee
Jul 27, 2009 | Watches
Pierre cardin running fast
Not enough information. Mechanical or Quartz for starters. Runs fast probably means it needs cleaning and service. Probably not a watch worth doing that with. They use cheap movements that can easily replaced but jewelers are too lazy or expensive to take a cheap watch to. These use cheapo movements.
Nov 15, 2008 | Pierre Cardin Watches
Watches Logo
958 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
