Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I have a d-link wireless g router.All of my computers that have wireless access are showing full wireless signals but none of them will connect to the internet.Can you please help?
  • 1,879 Answers
This might help
Posted on Aug 04, 2010
While connecting thru router,it showing limited access frequently
Do you leave the router switched on all the time? If not then this can be your problem as some routers can take up to 3 days to get full signal strength and keep it. When switching the router off and powering back up it has to search for the signal again. It will happen whether you are wireless or cable.
If you are wireless and router is always on it may be where it is located, walls can interfere with the signals so try moving it to another area to see if that helps.
Jan 01, 2013 | SMC EZ Connect g WEBT-G 802.11b/g Wireless...
Linksys router unidentified network....receiving full signals but showing unidentified network ...i hv checked SSID and key both are correctly entered....
Try resetting the router and then configure it again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 15, 2012 | Linksys WRT160N Wireless Router
D link keeps loosing signal
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Sep 19, 2012 | D-Link DIR-615 Wireless Router
Lan card is not connecting wireless connection available showing full signal but not connecting.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 15, 2011 | TP-LINK TL-WN350G, 54Mbps Wireless PCI...
I get a full wireless signal but when its connected to wireless there is no internet. The internet works when connected (ethernet) by bypassing the router, but there is no data transfer wirelessly.
The wireless router most likely has been configured with WEP or WPA or WPA2 encryption key.
Unless you configure the wireless card in your computer with the router's encryption key the computer cannot connect to the router by wireless.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 25, 2011 | Dell TrueMobile 2300 Wireless Broadband...
Wireless signal shows full full strength but then says limited access and I cannot connect wirelessly
Your computer isn't set up to properly get the right IP address and dns information. If you contact me I may be able to walk you through getting it set up correctly.
877-398-3242
Robert
Nov 20, 2010 | Belkin (F5D7231-4) Wireless Router
My daughter cant hook her acer aspire notebook up to my wireless router....its showing that it is full strength...but says limited connectivity or none...cant open internet....she is using windows xp...and...
The wireless card in the notebook needs to be configured with thw router's wireless setings ie. the SSID and the encryption settings.
To secure your wireless network from unauthorized access and toconfigure the wireless card in the laptop/computer, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 05, 2010 | Computers & Internet
My new d link router works fine..but my acer laptop wont pick it up...it says limited access? what does that mean? I have the security key..it has full signal..just says limited access
Most probably you setup WEP on your router and you're not typing the WEP Key on the computer you're trying to connect to the router.
You could try to remove all security first and once you can connect to the router you add it.
Ensure your wireless adapter's configuration matches the wireless configuration on router. Also ensure your wireless adapter driver status is working well.
If your computer OS is XP, you believed you have correct configuration and you have tried all solutions but still not working, then most probably it's due to winsock problem. You can even try winsockfix to fix the problem,here's the link WINSOCK. Hope it helps..
Dec 20, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Strong signal but no connectivity
ya thata right even if u move ur laptop upto 50 feet that will show the speed is good>and try this one try to change or upgrade the driver for ur pcmci card>and change the channel on teh w/l router try using 1>or 11>and rate me solved if its help full
Oct 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
844 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
