I have A problem whith my charger somethin is lussing inside and I want to open to fixe, thank you
    President:
  • 2,571 Answers
Most mains adaptors/chargers are not user servicable.
It can be dangerous to open them due to stored charge that may be left in the capacitors.
Even after switching off for a while, they can still store enough charge to give you a nasty shock.
Check your model on your manufacurers support page.
There may be a diagram for you
Posted on Aug 04, 2010
I can't switch it on
Might be the battery. Try turning on whith charger plugged in. Might try another known good charger.
Apr 01, 2014 | Nokia Cell Phones
Can I charch my new ryobi batery lithium whith the old charch
NO THE OLD CHARGER FOR THE BLUE ONE+ TOOLS WILL ONLY CHARGE NICD BATTERIES. HOWEVER THE INTELLIPORT DUAL CHEMISTRY CHARGER WILL CHARGE BOTH NICD AND LION BATTERIES. ALL BATTERIES ARE COMPATIBLE WITH ALL ONE+ TOOLS
Mar 01, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
Hi i have a dell 6400 notebook when the charger conected to notebook cpu usage is 100% and do not work corectly but when disconect the charger work normal and good, (whith battry) this problem happen when...
hi
when plug adoptor any trebal in mouse working if mouse aero do some problem buy orignal charger
becuse local charger is not work properly dell some model spaishaly 6400 ok if u have orignal charger change bettary
if fix your problem click yes for vote
Jan 06, 2011 | Dell Inspiron 6400 Notebook
Can I fix loose charger inside the unit of Magellan Maestro 4040?
  1. The only way it can be fixed is to replace thew whole motherboard. about $90.00
please rate our help to keep free sewrvice online
Aug 30, 2009 | Magellan Maestro 4040 GPS Receiver
Durabrand 7" Portable DVD Player DUR7
The charger=look on side of durabrand where power plug should go.there s/b somethine like [C+] or[ c-]
it is not really the letter C but the symbol of the outer rim of the plug that goes into DVD player.[C+] means that the outer shell of THE PLUG is negative (-) with the INSIDE being positive (+) with respect to a battery. [C-] again, the outer connection is (+) pos., inner connection (-) neg.
Look for power rating, as an EXAMPLE ( 5v at 1.5a [5 volts at 1.5 ampers]
May 22, 2009 | Durabrand DUR-1700 Portable DVD Player
Computer works by Battery only but not A/C cord
Your DC Jack Is Most Likely Failing From What You Describe....
The DC Jack Is The Port Where Your Charger Cord Plugs Into..
If Wiggled Enough, It Will Pry Loose From The Motherboard And Eventually It Will Begin To Short Out The Power, If Left Unrepaired, It Will Eventually Lose All Means Of Charging/Powering On Due To The Solder Being Burnt Away From The Positive Pins That Connect To The Mainboard....
You Might Want To Test Your AC Adapter With A Multimeter For Positive Power and Correct Voltage .. Sometimes A Broken Cord Will test Good If The Break Is Making Contact when testing....
So When Testing the cord... Slightly wiggle it to see if indeed there is a break in it or not...
Feb 06, 2009 | Gateway 450ROG Notebook
My xbox 360 wont play any disk, what should i do?
First try opening the tray and gently blowing inside like with your old NES systems. somethin could be blocking the eye.
Jan 04, 2009 | Microsoft Xbox 360 Console
Change ear pad
I hope below exploded view will help you how to open moz-screenshot.jpgMDR-V700DJ headphone.
Nov 03, 2008 | Sony MDR-V700DJ Professional Headphones
Blank screen
that happend to my old phone it was to do whith the charger there was a wire broken that stoped there being power to chare my hole phone. i got a new charger and it was fine .
hope it helps
x
Aug 20, 2008 | Cell Phones
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
