Question about Maytag MGRH865QDB Gas Range
We have a Maytag Range, model number MGRH865QDW, serial number 12229466LT. One day the keypad on the back of the stove quit working. The only key that seems to work is the "cancel" key. We have unplugged the range from the electricity for hours at a time, even overnight, and when you plug it back in the "clean" button seems to function. Since the oven is controlled by the keypad, we are unable to use the oven. Same with the kitchen timer. Help!!!
  • 1462 Answers
SOURCE: Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
Posted on May 18, 2007
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: GE Kitchen Range
have you tried clock then setting it
Posted on Feb 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
heatman101
  • 43501 Answers
SOURCE: KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Error code c-do how can I fix itunplugging and re plugging 24 hours later does not seem to fix the problem as as soon as I cook anything on my stove top it goes off again?
If this is a Samsung range, then the C-d0 error indicates a stuck keypad key. Try pressing down on each key to jog the stuck one loose. If that doesn't work, try pressing down on each key from an off-center position on the keypad.
If this doesn't work to release the stuck key, you probably need to replace the entire keypad. Please add a comment with the range model number. I will see if I can find the correct part number for your range. If the range is under warranty, you can contact Samsung for a warranty repair.
I hope this helps.
Jan 20, 2018 | Kitchen Ranges
Does a Maytag gas stove model # CRG9700BAL have to be vented. Im replaceing a stove that quit working with this one and it has no vent, but my old one did.
Old gas stoves were designed to be vented out. the newer stoves vent out the top at the back of the top panel. You may still need to have some kind of vent in the kitchen either a ceiling vent van or a range hood. At the very least a window in the kitchen. You may want to check with the local building codes about how to vent the stove and the requirements.
Oct 01, 2014 | Maytag Kitchen Ranges
What size breaker do I need for a maytag stove modle per4310baw serial # 14508789cl?
Go to the Maytag website on the internet and request the owner's manual for your model. It should have everything you need...download it!
Dec 25, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag stove with f7 code
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Dec 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
Dec 23, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MGRH865QDB Gas Range Logo
117 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
