Question about Sanyo Heating & Cooling
I have a Sanyo Air Conditioner model number KMS0912 that I am looking for either a manual, diagnostics, or schematics on. I am planning to remove and wash the filter but as it stands I simply cannot figure out how to remove any part of the exterior and access the internal workings of the machine. If anyone can provide me with information regarding how to complete the process of removing the filter, washing it, and returning it to its original position, I would be greatly obliged..
Master_Tech
  • 770 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Posted on Feb 17, 2008
aborcass
  • 2651 Answers
SOURCE: Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Posted on Apr 05, 2008
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
here are some icon meaning, this may help.
Posted on Apr 28, 2008
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
  • 108 Answers
SOURCE: can't find FURNACE filter
First you have to get the old filter/s out. If not it will cause big problems in a short time. Use a coat hanger to grab the filter if you cant reach it. When you remove the old filter you will probably see how to install new ones. I think more than one filter is required for this furnace. Note the sizes of the old filters and buy the same replacements.
Don't worry about cutting some tape if needed. You can get another roll at any hardware supply. If all else fails, measure the interior of the return box and buy the right size filters. Remember, you must remove the existing filters!
Ray
Posted on Nov 16, 2008
Need a manual to download for model FAH0818R1T
Good Morning Friend, this is Z. I am happy to assist you!
I see that you are looking for the manual of your Frigidaire air conditioner, FAH0818R1T; however, it appears above-listed model number is invalid. The serial, which lists your model number, is typically located behind the front grill by the air outlet or on the side of the cabinet. In the meantime, I have located the Owner's Guide to a similar air conditioner, model number FAH08ER1T1. Looking forward to hearing from you. Thank you!
Frigidaire Manual Search Results
Jun 15, 2014 | Frigidaire FAH086R1T Thru-Wall/Window Air...
Schematic diagram for sanyo tv AVM-2979P
Only two choices here aside from Google the model number with "service manual" is to contact Sanyo or look to see if the set is covered by a Howard W. Sams photofact manual.
May 15, 2012 | Sanyo AVM-2509S TV
Sanyo Dp53360 service manual
It was a little harder to find since you gave the wrong model number :)
Model number is DP55360. Here is the user's manual: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20(348A-)-38838316.pdf
Internet User's Guide: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20internet%20guide(358--)-34613941.pdf
Feb 12, 2012 | Sanyo Televison & Video
Need the schematics for 6721A or 6723A Coleman RV air conditioner
Check this link but look for model number on base of roof unit. Roof unit will be one number and whatever ceiling assembly will determine what to do with wiring.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 19, 2011 | Dometic Rooftop RV Air Conditioner
I need a user manual for this air conditioner. I need to know how to program the remote for it.
Follow this link, then click on your model. Then scroll down and look for "Resources" there you'll find all documentation you might need.
Jun 08, 2011 | Sanyo Split System Air Conditioner
I have a broken mode control switch. Where can I purchase a new one
Sears parts direct item 10
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Air-conditioner-Parts/Model-ACS072XJ0/1198/0904032/O2030196/00002?blt=06&prst=&shdMod=
This should be the control panel.
If your looking for the rotary switch it is item 15 same link.
Should the link above not work use this one and enter your model number ACS072XJ where is says find it fast:
This will bring up one selection choice. Click the only choice and the schematics for your air conditioner will appear.
Thanks for choosing FixYa
Kelly
Sep 28, 2010 | Whirlpool ACS072XJ Air Conditioner
Looking for a service manual for a Sanyo KS 3622, it is a split system air conditioner
google( sanyo air conditioning) , put parts or supplies with it and see if you cant hit something with that .. if there is a number with any of what comes up , have your modal & serial number ready and im sure you will get the manual .or they will lead you in the right direction im sure..
Aug 11, 2010 | Heating & Cooling
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
Heating & Cooling Logo
255 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
