Question about ViewSonic VX2235wm LCD Monitor
Monitor shut off after 30 minutes - ViewSonic VX2235wm LCD Monitor
  • 4,281 Answers
Go to start menu->control panel->Power option. Find "Turn off monitor" and set time as you want. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 04, 2010
My Sylvania lc320ss8 shuts of by itself after being turned on for 1 minute or two, I have tried unplugging for 30 minutes as suggested by the owners manual but still shuts off, please help
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 05, 2014 | Televison & Video
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
It's lg lcd w1943T that always shut down after 30 minutes and states power saving mode analog
check your video card and update the driver or pe install your video card. add cooling system. another is the motherboard capacitors
May 11, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My acer al1511 monitor started shutting down after 2 or 3 minutes, the green power led turns orange(like no signal). if i turn the monitor power button off and back on the monitor works for 30 sec to 1...
Here are the service manual (not usre which model you have, downloads are limit to two per day):
http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1511&kategoria=&kat2=all
You need to do some voltage checking make sure you do have 5 and 12v. The caps the secondary DC side should all be replaced at the same time, it may look OK but they can have high ESR, and they also should be low ESR type such as FM or FC series by PANASONIC. You can send me pictures if you want more help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 23, 2010 | Acer AL1511 15" LCD Monitor
Laptop screen goes white
Hi there Try to connect it to an external monitor and see how it goes. If the problem stays, that mean your video chip is probably defective. bad news since it's integrated in the main board. Replacement of this is costly. Unless it's still under waranty of course. If not, that means your inverter is probably defective and needs to be replaced.
Mar 31, 2009 | Toshiba Satellite A135-S2266 Notebook
KDS Computer Monitor loses video one half hour after booting up.
first, how long have you had it. if it has intergrated power supply,(does not have a big square box made onto the power cord) nine time out of ten your power converter/supply is going or is bad. return for a replacement. to the manufactuer not the store. they should replace it free of charge, if their honest. samsung has some models with this same problem.
Mar 18, 2009 | KDS K717s 17" LCD Monitor
Monitor goes blank after about 30 minutes. Then you can shut it off and turn it back on and it will work for another 30 minutes or so. What could cause this?
check your power settings (run>control>power options>change plan settings>advanced options>display)
you will see the setting for your monitor to power off
it should be set to 2 hrs or more if you plan on watching a movie or keeping the monitor on without having to frequently touch the keyboard or mouse.
turning adaptive display on may affect your situation as well. try switching it on.
This should do the trick for you. If not you may have an issue with either your video card or your monitors power supply.
(if the light stays on on the monitor when it goes blank but it doesnt repsond to the mouse or the keyboard, its a setting on your system or the hardware itself)
Good Luck!!
Mar 11, 2009 | Computers & Internet
Monitor goes to sleep after 30 minutes vl1919
Welcome to FixYa! The default power saving feature is turning the monitor off. To change the settings go to the Desktop>Right click on it>Properties>Settings and you will see power saving settings where you can choose "Never turn off" or a longer time interval. These settings can also be found in your Control Panel for all of the Power Saving features for the computer, monitor and hard drive. Steve
Jan 03, 2009 | Princeton Digital VL1916 19" LCD Monitor
My Panasonic TU-PT700U Digital media Receiver shuts the TV down after 10-30 minutes and the blue light flashes 5 times repeatedly. I have to unplug the unit and let it cool for several hours before it it...
Hi, I have a spare TU-PT700U that may be of use for you to solve your problem without having to replace your system.  My Panasonic onyx series monitor was stolen out of my house, but they left behind the TU-PT700U and cable.   If interested, respond to my craigslist post..
http://sfbay.craigslist.org/sby/ele/930283631.html
Nov 11, 2008 | Panasonic Televison & Video
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
FOR WINDOWS XP
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
POST BACK HERE AND TELL ME YOUR RESULTS OF THE ABOVE SO WE CAN TRY SOMETHING ELSE
Jan 16, 2008 | Computers & Internet
ViewSonic VX2235wm LCD Monitor Logo
47 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
