Question about Sharp Microwave Ovens
I had a Sharp Carosel oven Microwave, model# R-1450. When I close the door, the light is on and you can hear the normal working sound, even though I didn't press anything. In fact it doesn't heat after you press time. Turntable doesn't turn. Thanks. Michael
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link….
http://www.gallawa.com/microtech/data4a.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
My Sharp Carosel volume got really quiet. Is there an easy fix?
If you are referring to the beep when you press any function,the beeper on the board may have failed.
The two other sounds are :i. there is a fan that comes on when start is pressed and, ii. the other sound is a heavy hum also when start is pressed.This comes from the transformer and maybe the magnetron tube. If you are not getting these sounds then troubleshoot these areas,careful though, the output voltage from the transformer is about 1.5kv
Mar 02, 2014 | Sharp R-1480 Microwave Oven
Microwave makes noise after door is opened jenn air model jmv9169ba
Microwave ovens emit powerful radio waves and in general for safety reason should only be used when in perfect working order. It usually costs more to repair an older microwave oven than to simply replace it.
Suggest buy a new one.
Mar 02, 2018 | Jenn-Air JMV9169BAS Convection Microwave...
Why does the fan on my Sharp Carosel II microwave continue to run? Model R-8560
From the description one of the door switches is defective, if you have a digital meter then I will walk you through the testing phase.
Jul 06, 2012 | Sharp Microwave Ovens
Microwave hums and panel lights up when plugged in
To many variables and testing needed to explain, but my feeling is that the board is faulty. Have had that happen on a few occasions but with a different brand. On occasion ive seen microwave come on when door is opened but that was loose limit switches for the door latch. Normally humming is due to a faulty magnatron, but it can also be from incorrect voltage onto the magnatron due to the faulty board. Need to concider if repair cost is worth it even though Sharp is excellent microwave.If you do, i would start with the board.
Sep 27, 2009 | Sharp R-1610 Microwave Oven
Clock works but No carosel turning or heat to microwave. Model R-1501 sharp
This is probably a bad bottom door switch or its mount is broken or misaligned.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Jan 10, 2009 | Sharp R-1500 Microwave Oven
No power
That would probably be a bad secondary interlock (bottom door switch) or its mount.
You will need the
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 11, 2008 | Sharp R-1480 Microwave Oven
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
