I have a Novi Tech paper shredder model PS-064/B. The gear that meshes with the moter gear is striped. Wher can I maybe buy one? Also I don't have the basket. Where can I buy one?
fellowesrep
  • 102 Answers
SOURCE: PS-70 Shredder problem
The plastic safety interlock tab is located inside the bin front center if it is bent or broken it will not engage
Posted on Feb 22, 2008
  • 329 Answers
SOURCE: Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Posted on Jun 24, 2008
SOURCE: NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Posted on Mar 22, 2009
  • 8 Answers
SOURCE: Shredder motor runs but gears are not engaging and
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Posted on Aug 08, 2009
FixinFax
  • 3085 Answers
SOURCE: My PS-65C,won't work because.............
Don,
Sorry, no spare parts are available.
Posted on Sep 18, 2009
Gears are not rotating; motor works though
I guess you have made sure that the cutters are not jammed by bits of paper and card?
Mar 23, 2014 | Office Equipment & Supplies
Shredder No Longer Does
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Dec 27, 2013 | Royal Jaws Shredder
Need a manual
Can I purchase the plastic geers for a novi tech shredder. Model: PS-307B. Mine stripped.
Oct 25, 2012 | Office Equipment & Supplies
I have a privay Guard model PS-029/MB and I have a brocken plastic gear, can I find this part online?
I have the same problem. The gear that the motor drive shaft touches has been shredded to pieces. when contacting the second gear. The secondary gear is plastic and absolutely WILL shred itself to pieces over a short lifespan (<5yrs) because metal vs plastic is a losing combination.
Feb 02, 2011 | Techko Identity Guard 6-Sheet Strip Cut...
TS3300 PAPER SHREDDER. I NEED THE SWITCH CABLE COMBINATION
where can i buy a gear for my paper shredder model ts 3300
Apr 26, 2010 | Tech Solution TS-4500 Shredder
It seems a sif soemthing is blocking the shredder
you will need to take it aprt. over time paper dust gets in the gears, transmission and bushings. you will need to remove all the dust and inspect the drive gears. mosyt of these come apart buy taking it off the stand. flipping it over, messy. removeing the bottm bolts/screws. then maybe remove trans mission cover.
Oct 28, 2009 | Tech Solution TS-4500 Shredder
The plastic gear in my Fellows Powershred PS 60CC paper shredder is ruined. Is it possible to buy a replacement gear anywhere?
WHICH OF THE PLASTIC GEARS FAILED? FELLOWES HAS A REPLACEMENT THAT CHANGES A PLASTIC GEAR TO A STEEL GEAR-A GREAT IMPROVEMENT.
Oct 06, 2009 | OfficeMax 0M96431 Shredder
Looking for a replacement gear for our shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 03, 2009 | Tech Solution TS-6000 Shredder
Jun 03, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
Marvin
Marvin
