Question about Zanussi ZX56 / 4 Bottom Freezer Refrigerator
Zanussi zx 56/4 The lower freezer section is over freezing. Top part fride is ok. Keeps making a clicking noise and occassionly a loudish bang ? Could this be the thermostat ?
Did you find the problem because mine is doing the same thing?
Posted on Jan 13, 2011
Fridge section keeps freezing up.
Hi,I had trubble with my fridge so done a bit of reserch the main reason for the fride freesing up is,
fridge not set at right temp (3 to 7 c ) or vent where water drains blocked,shelves not in right place as in manuel,and if you put veg that has alot of mosture content can also course freezing at the bottom of the fridge,hope this was some help,maybe buy a fermomiter to test.
Jul 03, 2016 | Refrigerators
Sounds like ametal object in drum but there is nothing visible its making a loud banging noise
hello they usually make this noise sometimes a few thing to check make sure the washer feet are adjusted properly if ok .with the power off you could take the top off see if the 2 springs are attach either side of the washer sometimes the snap or come loose also have a look at the suspension legs make sure there tight or not broken hope it helps
regards
shaun
Mar 27, 2011 | Zanussi ZWF12070 Front Load Washer
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser won't shut off nor will the ice dispenser motor
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Zanussi ZX 57/3 fridge and freezer not working
Hi . Most freezers with the condenser coils at the back do not work when the temperature where it is placed gets below (( 5 degree c ))?? IE in a garage if it is freezing weather outside. One solution is somehow to keep the condenser compartment warm. Check the makers website. for what they say about it
Jan 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Top Freezer temperture warm, not freezing food
clicking noise is probably compressor relay operating and compressor not starting. probably compressdor faulty
Nov 14, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Zanussi ZX56 / 4 Bottom Freezer Refrigerator Logo
139 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
