Question about Apple iTunes
My itunes just stopped working one day and now i can not reinstall it on my computer
    Scholar:
  • 166 Answers
Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
How ToFor Windows Vista or Windows 7, see this article.
Expand All Sections | Collapse All Sections
In some rare instances, it may be necessary to remove all traces of iTunes, QuickTime, and related software components from your computer before reinstalling iTunes.
Use the Control Panel to uninstall iTunes and related software components in the following order:
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes Note: iTunes Store purchases or songs imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
  1. Quit iTunes.
  2. From the Start menu, choose Control Panel.
  3. In Control Panel, open Add or Remove Programs.
  4. Select iTunes from the list of currently installed programs, then click Remove.
  5. When asked if you would like to remove iTunes, select Yes.
  6. After the uninstallation is complete, do not restart your computer if you are prompted to.
  7. If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
  8. In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
Removing QuickTime
  1. Quit QuickTime Player.
  4. Select QuickTime from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove QuickTime, click Yes.
  7. If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
Removing Apple Software Update
  1. Quit Apple Software Update.
  4. Select Apple Software Update from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove Apple Software Update, click Yes.
  7. If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
Removing Apple Mobile Device Support
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, open Add or Remove Programs.
  3. Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Mobile Device Support, click Yes.
  5. After the uninstallation is complete, do not restart your computer if you are prompted to.
Notes: Do not manually delete the Mobile Device Support folder located at C:Program FilesCommon FilesApple. Use Add or Remove Programs as described in the steps above.
Removing Bonjour
  2. In Control Panel click "Add or Remove Programs."
  3. Select Bonjour from the list of currently installed programs then click Uninstall.
  4. When asked if you would like to remove Bonjour click Yes.
  5. After the uninstallation is complete do not restart your computer if you are prompted to.
Removing Apple Application Support (iTunes 9 or later)
  3. Select Apple Application Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Application Support, click Yes.
Verify iTunes and related components are completely uninstalled
  1. Restart your computer.
  2. After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
  3. Open the Program Files folder.
  4. Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
  5. Right-click the iPod folder, choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  6. Right-click the QuickTime folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  7. Right-click the Bonjour folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  8. Open the Common Files folder.
  9. Right-click the Apple folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  10. Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
  11. Open the Windows folder.
  12. Open the System32 folder.
  13. Right-click the QuickTime file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  14. Right-click the QuickTimeVR file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  15. Right-click the Recycle Bin and choose Empty Recycle Bin
Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
Additional Information iPodService.exe Alert Follow these steps if the message, "Cannot delete iPodService.exe: It is being used by another person or program" appears when you try to delete the iPod folder.
  1. Make sure that iTunes and the iPod Updater utility are not open.
  2. Press and hold Control-Alt-Delete. Select Start Task Manager.
  3. Click the Processes tab.
  4. Locate "iPodService.exe" in the list.
  5. Click "iPodService.exe" and choose End Process.
  6. Quit the Task Manager.
Posted on Aug 18, 2010
I updated itunes today 12.3.3 and now it won't open on my computer - windows 10. It says a problem caused the program to stop working correctly.
Fully uninstall iTunes, reboot the system and then reinstall iTunes from the latest version download on the itunes web site.
Mar 29, 2016 | Apple iTunes
Itunes on Macbook Air won't stop skipping music
yeah,,, you need to reinstall it... find another one ITUNES 10.6.3 ...unistall the old one... go to your COntrol panel... click ADD or remove programs... find the installed ITUNES.. and then riight click to it.. and choose UNInstalled.. so after that.. you can reinstall it again.. !!
hope it will work.. and i hope this can help... thanks
Aug 06, 2012 | Apple MacBook Air
Apple Application Support was not found. Apple Application Support is required to run iTunes. Please uninstall iTunes, then install iTunes again. Error...
How did you uninstall itunes? If you run into an error, or your computer while your itunes was installing, it could leave things behind messing up all the other installations as well. What you need to do is first of all make sure you don't have any instances of itunes open, or trying to be opened. Then you can go ahead and run the uninstaller on itunes.
Then you will need to go into explorer (windows+e, or right click on your My Computer icon and press "explore" from the menu), navigate to C:\Program Files\ and delete the itunes folder completely. If you get an error saying something to the effect of "This file/folder is being used by another program, please stop that program and try again." go ahead and restart your computer, and try to delete the folder again when your computer comes back up.
Then try and reinstall it, making sure that you are downloading the correct version of itunes for your operating system.
Dec 27, 2010 | Apple iTunes
Itunes froze so i uninstlled it reinstalled it but still frozen
I would do a complete uninstall and reinstall follow these directions to a
" T " ! you should be fine - if it dose not re-post results and i will provide additional steps
win xp
win vista , 7
Mac
Apr 15, 2010 | Apple iTunes
The registry settings used by I tunes drivers for importing and burning cd?s and dvd?s are missing. This can happen as a result of installing other cd burning software. Please reinstall itunes. Any new...
Just reinstall Itunes again, you do it in this way :
Go to "Start" and then "control Panel" and then "Add and remove programs". Here you find the icon were it is writed ITunes, highlight it and choose to uninstall it.
Uninstall Itunes, reboot the computer, install itunes, thats it :O)
Have a nice day
Hope that helps
IF not then return here
Please rate my answer
Oct 11, 2009 | Computers & Internet
My P5PE-VM sound card suddenly stopped working.
if you cannot reinstall it or it is installed correctly that means that your sound card is in fact broken =(. you will need to replace it. soundcards are generally inexpensive depending on what you will be using it for.
Jun 05, 2009 | ASUS P5PE-VM Motherboard
Song stops midway and moves on to next song
if there still new apple has an excelent return and repair program for factory defects.
Apr 15, 2009 | Apple iPod classic MP3 Player
Computer wont recognize ipod
ok if u have windows u need to do a search and type in anything that has to do with ur current iTunes and delete everything but the music folders and after u need to reinstall itunes and then plug in ur ipod after iTunes is open and try restoring the ipod.
Feb 28, 2009 | Apple iPod nano
Itunes v8.02.20 will not open.
Try uninstalling iTunes, Apple Software Update, Apple Mobile Device Support, and Quicktime. (Note: When you uninstall each of these, it asks whether you want to restart your computer. Say no until you have unnstalled the 4th one, after which restart your computer).
Then, reinstall iTunes. It should work.
Feb 14, 2009 | Apple iTunes
Ipod 1st generation doesnt show up on itunes & wont restore
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
May 12, 2008 | Apple iPod nano
Apple iTunes Logo
242 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
