Question about Whirlpool Refrigerators
We have a whirlpool GS6SHA conquest side by side and the middle bar between the frig and freezer is hot to the touch. what is wrong?
  • Whirlpool Master
  • 1,606 Answers
Either the fan which cools the compressor ( behind the bottom panel behind the refrig ) has stopped ( possibly something caught in the blade or bad fan motor ) , or the coils in front at the bottom behind the kick plate , need cleaning badly .
Posted on Aug 04, 2010
Whirlpool conquest gs6sha
The refrigerator may not be level side to side and front to back. This is very important to ensure proper functioning of the drain
Sep 28, 2013 | Refrigerators
I have the whirlpool conquest GS6SHA and it is not staying cold enough and the freezer is not defrosting properly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Whirlpool Refrigerators
Middle panel hot to the touch
This is an indication that the condenser is overheating. It could lead to problems if not addressed. I have put together some instructions on how to remedy this. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 12, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Bar bewteen frig and frezer is very hot to the touch.
Yes that is normal. It prevents moisture from building up.
Apr 04, 2009 | Whirlpool GS5SHAXN Side by Side...
Inside the door panel
If you mean the area where the gasket is...yes.  This is a mullion heater designed to prevent freezing the gasket to the box.  It should be slightly warm.  Some units have the option of turning thi feature off.  Check your manual.
Nov 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
261 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
