Question about AEG MCC663 Microwave Oven
My AEG MMC663 microwave oven, blew a fuse. Now has power but does not heat or turntable turn
I have a GE JE2160sf01 Microwave oven. The oven blew the bulb and I have replaced it. Since replacing the bulb, the turntable will not rotate. I have checked and replace the motor, but still have the...
If you replaced the motor and turntable still does not rotate, either the motor is not receiving power or the the drive that turns the tt is not working because of slippage, etc.
Nov 08, 2015 | GE Microwave Ovens
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Aeg micromat 153e
You rather have a bad turntable motor or a stripped turntable coupling.
Jun 22, 2014 | AEG Microwave Ovens
AEG MCD2664E-m - plate not turning
There is no separate fuse only for turntable motor. Usually there is two fuse, one in High Voltage section (instead fuse could be HV protect diode) and another one for 220 V (light, turntable motor, fun motor, display....). If light work normally then is turtable motor faulty.
Dado
Mar 21, 2014 | AEG MCD2664EM 60cm Built In Microwave &...
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Turntable, lights and fan inop
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
AEG MCC663 Microwave Oven Logo
74 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
