Question about Garden
I have a tpw 2200 pressure washer that has lost high pressure. i have low pressure but not high pressure.\r\n The machine i have is a titan tpw 2200 if some body can tell me what is wrong please help. Thank john
  • 21 Answers
Pour a large amount of liquid TSP into the fresh water inlet where the garden hose connects and let is sit for a couple of days.
This is how I fixed my pressure problem
Posted on Aug 29, 2010
Shut itself off and will not restart. New gas in tank
Check reset. alot of machines of this type have one. Also the pressure sensor or relief valve is designed to stop the motor if to much pressure builds up in system. May check this in your manual..
Jun 05, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
I HAVE A TITAN MODEL TPW-2200 AND WHEN I RUN IT IT SPITS THE OIL OUT OF THE BREATHER HOLE
Sounds like you may have a crack in the cylinder or the engine block. Sorry, but there may be no fixing the proble. Good Luck!
Jul 30, 2011 | Garden
I have a husky 2200 pressure washer. What do I set gap on spark plug. (Lost insturctions)
20 thousands or about the width of two match book covers stacked.. there not that fussy, good to be close though
Jun 06, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
I have a kattcher 6 hp, 2200 psi pressure washer, not working
Does the end of the output nozzle have a setting for pressure / no pressure? Mine (not the same model but also a Karcher), allows you to spray low pressure/high volume which is what comes from your hose just by teisting the end of the wand.
Aug 24, 2009 | Garden
Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Flow Rate Question
the flow rate in litres per minute (or litres/hour) is a very important measure of the cleaning ability. DIY machines commonly have flow rates as low as 6 litres/min. Heavy-duty industrial units vary from 10 to 40 litres a minute.
Aug 27, 2008 | Psi Blue Max 2200 High Pressure Gas Power...
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Garden Logo
672 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
