Question about Fuji Cycling
I have a fuji newest 3.0 road bike and the gear cable has snapped. How do I replace the cable for the rear derailer? where can I get the schematics for this bicycle? Thank You Jacob Soltys
  • Anonymous Mar 25, 2014
    Rear derailler repair
    Brigadier General:
  • 8,546 Answers
Http://parktool.com/repair/readhowto.asp?id=64
http://parktool.com/repair/readhowto.asp?id=113
Be advised, special tools are required for cutting the cable housing and inner wire.
Posted on Aug 05, 2010
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
Sep 01, 2014 | Shimano Rd TX50 Tourney Mega Range Rear...
Do I have to buy new bikes to get higher range of gears?
Actually no! you can visit your bike shop and ask them for higher range. What they do is change the front wheel ring in order to give you higher range.
Jan 17, 2013 | Cycling
I have a Huffy Verona 18 speed with the Soleus shifter first the cable wasn't working so I put wd-40 down the cable that has freed it up but I'm having problems getting the rear railer to change...
When I have had that trouble with my own bike, I have taken the cable off and replaced the vinyl housing. If that isn't an option, get the cable as free as you can, then lubricate the rear derailer, and with a cloth, so as not to soil your hands, grab hold of the derailer and work it back and forth to free it up. Riding the bike causes all the road grime to accumulate on the derailer making it stick.
Hope this is of some help
Joe
Aug 30, 2011 | Cycling
I have a Kawasaki kx20s 10 speed boys mountain bike that needs the rear brake cable replaced and both the front and rear derailer gear cables adjusted or possibly replaced. Is there a manual or diagram of...
1st The brakes: Once you have ran the cable through appropriate cable holders and to the brakes-you hold the brake calipers shut-remove excess slack from cable by pulling on it with pliers and back off a little before tightening the nut holding the cable(amount you have to back off tension depends on how strait your wheel is).
The Front Derailer doesn't usually have adjustment so you put the gear lever in top gear-loosen the nut holding the cable-push the derailer into the right position-remove slack from cable with pliers then tighten the nut.
The Rear Derailer: will need to be done the same way if your running a new cable..*But there is a screw on the derailer near the junction of the 2 parts that adjusts the position of the derailer- so you can do minor adjustments-**NOTE-there are 2 screws- 1 changes the position in or out and the other changes the angle**
Aug 26, 2011 | kawasaki KX20 Boy's BMX Bike
2010 Fuji Newest 4.0 Road Bike user manual
The Fuji Newest does not use any special user manual. You can go into any bike shop and they will have an owners/ users manual for a similar road bike. The manuals are written generically so they only produce one for all there models of road bikes.
Most shops will also be happy to give you a brief demonstration of how to use the brakes and shifters, in fact the shop where you recieved the bike will most certainly be happy to provide this service. I have never heard of a shop charging for taking a few minutes to show a rider how to safely operate their bike, and having some one show you on your bike is preferable to a generic manual.
There are also some decent resources on youtube that demonstrate how to shift and brake your road bike, Have fun with your bike.
In the US. Performance bikes is a large Fuji dealer that always has extra manuals, if your near one.
Dec 04, 2010 | Cycling
I need to change my back gear cable
Shift your rear derail down to the smallest cog on the cassette. Loosen the nut that holds the cable onto the derail. If you are reusing the outer cables back the inner cable out to the shifter. If your replacing the outers also, note where they are installed. There should be an allen screw on the bottom of the shifter that will free up the shifter and expose the knob on the end of the cable. Pull out the old cable and install new in reverse. Insert the cable into the clamp on the derail. Pull the cable taught with pliers while tightening nut on clamp. Run through the gears while on middle ring on front. Turn barrel adjuster on derail in and out to dial in shifting. That should do it. Good luck and let me know if you have any problems.
Oct 04, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Hufyy 26" Tundra 18 speed bike....GEars are clicking
Sounds like the rear derailer needs adjustment. Are you handy with tools? There should be a micro adjuster on the cable for the rear derailer. It might be located at the shifter on the handle bars, or at the rear derailur. Follow the cable from shifter to derailer, Look for an adjusting nut, when you find it, turn it counter clockwise to remove slack from the line. Go one turn at a time, ride it and shift through the gears. Repeat until the noise stops or you run out of adjustment. If that doesn't fix it, you need to srew the adjuster all the way back in, shift it to the highest gear, loosen the bolt the holds the cable on the derailer and pull the cable tight and tighten the bolt back down. If you are unsure about doing this, go to your local bike shop and have them fix it AND show you how to do it.
Aug 12, 2010 | Cycling
Jumps out of gear under load and unable to change
need to oil and adjust the rear derailer some have a screw adjustment others are loosen cable lock adjust cable and relock clamp
Nov 09, 2009 | Cycling
Rear derailer adjustment keeps coming out , gears slipping , adjustment on the cable is wound in as far as it can . 7800 series
take it to a bike shop the will make it run nice and smooth i have been road biking for 2 years now
Aug 31, 2009 | Cycling
Cycling Logo
399 people viewed this question
Top Fuji Cycling Experts
Donald Ayers-Marsh
Bill Packer
Andy Brown
Andy Brown
Are you a Fuji Cycling Expert? Answer questions, earn points and help others
