Question about GPS
My liter jack wont work and i need my gps to charge and it wont charge either how do i fix it
  • 3 Answers
Look in your car owners manual for the fuse diagram, replace the lighter fuse.
Posted on Aug 04, 2010
Garmin reports low battery, turns off in 2 seconds even when connected to car battery
Check to make sure that the rear USB jack isn't loose. This is a common problem on ALL nuvi's that are charged by a USB jack only. If the jack is broken, the battery will not be charged. When you plug in the charger, the battery icon with green bars should go away. If you can still see it, your USB jack is broke and needs to be replaced. I've replaced these many times. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Oct 08, 2012 | Garmin nuvi 250W GPS Receiver
Charging connector is loose
Yes, you have found the problem. The mini-USB jack is broken, preventing the battery from being charged. However, you can charge the battery by using the 660's snap in cradle and bypass the USB port. If you want the jack replaced, please see this link:
You will want to fix the jack because you will not be able to update the firmware or map until the jack is fixed.
- Jim
Dec 05, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin charger has red light on and wont charge
mine too. Its brand new. Worked OK in my car for a couple of small trips, and unfortunately I didn't notice the lights status on the charger. Then lost satellite reception (not being charged at the time). Now red light on car charger and kept turning off/won't turn on. I have an old mains charger from garmin 660 which has a malfunctioning antenna and this 1490 was meant to replace ! Its charging now anddoes turn on, but no answer yet I'm afraid. I intend to register it with garmin and log a call with them. Also looking at the manual, it says there is a fuse in the head of the charger which should be checked. I haven't done this yet, but not sure if red light would be on if fuse had blown ?
Mar 13, 2010 | Garmin nuvi 255W GPS Receiver
I pluged in my Magellan Roadmate 1200 in to the computer with the usb cable thinking it would charge. It now says it has a fatal error and that screen won't go away. Did I erase the memory on it? I...
im sure its not trash, but i dont think the usb will charge this model ( the usb wont charge all models of magellan, only some) while the unit is on, use a paperclip and insert it in the small hole on the side of the gps, that should return it to its normal state.
if you need further help, just let me know.
bill
Sep 03, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
GPS wont work!!
most likely the power port is damaged and needs replaced.
i repair those magellan gps if you need help. if i cant fix it there is
no charge. wmetz@comcast.net
May 28, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Garmin charger problems
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin nuvi 200W GPS Receiver
Not charging
Hello brocstar,
You could have a problem either with the power cord itself or the DC input jack on your GPS.
When you say you wiggled the "power lead" to fix the problem I believe you are referring to the actual power cord. If so, it's possible that the cord has a short that has progressively gotten worse and eventually caused the cord to fail. In that case it should be a relatively simple fix to simply replace the power cord and that's where I would start.
If replacing the power cord doesn't work then the problem likely is with the GPS itself and the unit may need factory service to repair the DC jack, battery or charge circuitry.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | Navman F20 GPS Receiver
GPS Logo
21 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
