Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Lock our television was locked unintentionally and there are no command on the remote to unlock. How can we unlock the television? We can't watch anything. Thanks, Glenda
    Sergeant:
    Champion:
  • 319 Answers
You will have to have access code or password to change settings. Or contact set manufacturer technical service for override procedure
Posted on Apr 26, 2008
Code b3138 door lock circuit high on 05 Chevy Astor van what does that mean
Do you know anything about automotive electronic's ? What a BCM is ? body control module (computer) or anything about automotive electrical circuit's ?
DTC B3137 or B3138
DTC Descriptors
This diagnostic procedure supports the following DTCs:
• DTC B3137 All Door Lock Circuit Low
• DTC B3138 All Door Lock Circuit High
What this is saying is the BCM saw a higher then normal voltage on that door lock circuit . Looking at diagnostic trouble shooting chart for that code should be done by a qualified service technician .
Circuit Description
The body control module (BCM) monitors and supplies an output voltage on the door lock control circuit. When the BCM receives a lock command from the remote control door lock receiver or an automatic door lock function has been activated, the BCM supplies voltage on the door lock control circuit to LOCK the doors.
Install a scan tool.
With a scan tool, command the door lock relay ON and OFF.
Does the door lock relay turn ON and OFF with each command?
Disconnect the door lock relay.
Probe the door lock control circuit at the door lock relay with a test lamp connected to a good ground.
Does the test lamp turn ON and OFF with each command?
Learning how to test electrical circuit's an using a wiring diagram an a DVOM - digital volt ohm meter or test light is how to find the problem .
Electric Testing Techniques You Need to Know
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size . Under system click on body & accessories ,then under subsystem click on power lock's . Click the search button ,then the blue link's one at a time . You may want to watch some video's on how to read a wiring diagram .
Dec 13, 2017 | Cars & Trucks
Atv will turn on but stays on one channel and menu button and channel button will not work, and there no picture.
Most TV's require to be set on channel 3 with the TV remote again I say with the TV remote then if you get a screen run the channel lookup command from the TV remote, that should do it for you. In addition make sure the TV is set to the correct AV input with the converter box remote, your ISP can help with that part
Good Luck Ed Pinero
Feb 05, 2013 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
If my TV acts like it is locked but is not then what is wrong with it?
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
• Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
•Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
• Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step .
Jan 08, 2013 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
Je cherche un code pour telecommande one for all urc-4041B01 pour television jvc merci
Bonjour
Codes de configuration pour JVC TV avec la t?l?commande URC4021 sont
0463, 0053
OK.
Aug 18, 2011 | Universal Remote Control URC4021 Universal...
Is there a universal remote control that will work with Westinghouse LTV-20V2SL?
Universal remotes are cheaper,but those codes u enter for any tvs any models might work might not.No,not any univeral remotes have any particular tvs brands,just a list of a universal codes for the tvs brands it covers.Try website like Remotes.com to buy a remote same as ur original remote.Than u don't care about codes or taking chances of those codes,will or will not work for ur tv.
Nov 27, 2010 | Westinghouse LTV-20V2SL 20.1 in. ED-Ready...
Harmony 890 Remote - kids watched a movie last night and now the screen is zoomed and we don't know how to get back to regular view. They swear they only used that remote.
On the remote, press "Devices" and then select the TV. There should be a command on the LCD screen that is called somethine like Zoom, TVZoom, or a ratio such as 5:10 (the numbers could be anything). If not, test all of the commands. One of them will fix it.
Jul 25, 2010 | Logitech Harmony 890 LCD Remote Control
1994 Lexus LS 400 Valet Lock Stuck - Can't Open Trunk
you have to have a main key. you may be able to remove the panel and release that way. under dash. pull cable.
Mar 29, 2009 | 1994 Lexus LS 400
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
