Question about Refrigerators
I need fan - Refrigerators
  • Refrigerators Master
  • 1,606 Answers
You get fan
Posted on Aug 04, 2010
FAN NOT WORKING
Need more info. Is it your ceiling fan, radiator fan, desk fan, CPU fan, case fan or PSU fan. also what is the make and model of your motherboard. or you could buy a fan from your local computer shop. If you carry your broken one with you they will be able to sell you a matching item.
Mar 04, 2013 | Jetway Computers & Internet
HOW TO REPLACE CLUTCH FAN
to remove clutch fan you need to remove upper fan shroud, you need large wrench to remove the fan clutch retaining nut to remove fan and clutch away from the engine drive belt should keep pulley from turning while loosen fan clutch retaining nut.if pulley belt turns while loosen fan clutch bolt remove drive belt use strap wrench hold pulley while you remove fan clutch bolt this procedure for checvrolet if you working on volkswagon you need spanner wrench hold the idler pulley while you use large wrench to loosen the large drive nut to fan clutch. you have to remove fan with clutch from engine then you can remove clutch from fan you can go to auto parts stores rent a spanner wrench try auto zone they rent out tools.
Jan 05, 2012 | Cars & Trucks
Vehicle overheating, cooling fans appear to be inop. no fuse for fans
sounds like you need a tempreture censor switch that turnes the fan on
if the fan doesnt com on you can i dont tell every one this un plug the fan
run 2 wires to the fan one neg. one pos. from the battery if the fan
comes on than you no what you need if not u need a fan be ware
it will spark when you hooh it up
i hope this helps you
bob
May 31, 2011 | 2001 Volkswagen Golf
Im on my 2nd big buddy and both of them the fan has gone out, the first on went in a week, and this one last a couple of months.
fans
1. oil the bearings,sae 30 or wd40 for places you cant get into.
dont take fan motor apart unelse you realy have to.
dont let your fan motor bearings get worn egg shaped from lack of oil.
2. make sure fan blades not hitting or scraping fan housing and fan blades are securely fastened to fan motor shaft.
3.mr heater fan motor is 12 volts DC , so it may have a segmated comutator and brushes.
I dont know because i have not yet needed to take my mr heater
fan motor apart but i have worked on hundereds of ac fan motors
in the past 65 years.
4. keep fan motors from getting wet. they hate water.
5. keep fans clean, they dont like foriegn materials.
Your specific problem: first fan 2 weeks,second fan 2 months.
how much you use them, are you wearing the brushes down?
Getting fan motor wet? foreign material getting pulled into fan or fan motor? off/on switch work ok. batterys good,battery contacts ok? fan transformer 110 vac to 12 vdc good? fan bearings oiled?
need more info to diagnose properly.
all of the above needs to be checked out to tell whats happened.
fan & fan motor needs to be inspected.
Feb 21, 2011 | Mr. Heater Big Buddy Heater
Fan does not come on, what should i do? It is not
Check the fan switch on the engine and the relay as well
Jun 03, 2010 | 1997 Honda Accord
I need to install a ceiling fan in a room where there is no lighting fixture, only a switch that controls floor lamps
If you have wiring experience it can be done, if not I recommend picking up a do-it-yourself wiring book from home depot or other home improvement store. To make your job easy you can run your fan and the floor lamps off that switch as the fan does not use that much power. You will also need access about the ceiling to put up a fan box to hold the fan otherwise you need to pull some ceiling down; enough to go from joist to joist to put in the box. The fan box you need to get is a Westinghouse fan box capable of holding at least 50lbs. Then all you need to do is run your wires and attach your fan.
Apr 22, 2010 | Hunter 52" Ceiling Fan With Light And...
Radiator fan
either the fan is bad or you need a temp. sensor, to check fans, run a wire from positive on fan wires to positive on battery, if need be ground fans!! if they are ok the fan should start running,,
Sep 01, 2009 | 1991 Ford Mustang
My fan is clicking. Does it need oil?
If this bis a ceiling fan, then most likely the blades need tightening.
The bearings on MOST common ceiling fans these days are permanently-sealed, no oiling required or possible. Some older fans such as some of the Hunter units can and should be oiled.
Aug 23, 2009 | Chateau Dryers
Dometic 57915.531 - high fan does not work
If it is a wall mounted thermostat, then you need to check the control box mounted on the inside of the unit. Remove the inner shroud to access. Check for power on the blue wire entering the control box from the thermostat, this is the high fan circuit. There should also be power on the orange(or tan) wire from the tstat. This is the fan circuit. Both these need to be hot with 12VDC for the fan to run on high. If you have power there, try removing the cover from the inside and access the squirrel cage (fan blade) inside the unit, turn the tstat to High fan and try starting the fan motor by hand. If it starts, then you have a bad fan capacitor. If not, check power to the fan on the top unit and all wiring leading to the fan. If you have power to the fan and it still does not run, you need a new fan motor.
Hope this helps,
Jeff
Jun 08, 2009 | Dometic 57915531 Air Conditioner
Heritage lancaster ceiling fan
Where can I find parts for this fan: Kids 30" ceiling fan multicolor - I need new fan blad arms
Jun 19, 2008 | Dryers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
