Question about Kenmore 22642 Top Load Washer
Grease leaking from bottom of washer - model 110 24992300
  • Kenmore Master
  • 2,699 Answers
Sounds like you blew the tranny,is the washer pinning correctly,if it is it won't be after long,any oil or grease is coming from the tranny
Posted on Sep 01, 2010
Washer slinging grease from bottom of tub onto sidewalls of washer. Also beginning to leak water while it is agitating and spinning. Do I need Tub Bearing kit?
You need the outer tub seal as a minimum for the water leak. The grease is a different mater, it could come for several places by the most likely in the transmission, not the bearings.
Jun 29, 2011 | Maytag Washing Machines
The washing machine is leaking water from the bottom of the unit...
look in bottom part of machine are in side wall dirty with grease if so leaky centre pole if so not good news replace machine to costly to repair
if inner walls clear of grease check for loose hose and fittings
Jun 12, 2011 | Maytag MAT13MN Top Load Washer
Water leaking out of the bottom of the pump - low pressure leak, light stream
Will be a gasket, o-ring or seal that has blown. Could even have a cracked fitting or a split hose.... remove housing where leak is coming from and inspect. call service part agent and order new part (make sure you grease seal or o-ring with rubber grease. If it is a gasket you may need to use a gasket sealant and find out what the torque setting are for the component you have disassembled.
General quide is: 10mm head = 10 - 12 newton meters 12mm Head = 18-20 newton meters
Hope this helps... hard to diagnose accurately with your vague description
Feb 10, 2011 | Karcher 2500 PSI Pressure Washer
I installed a new grease cartridge in my grease gun and grease does not come out when triggered.
If the gun was working properly before you changed the cartridge, The gun is air-locked
Two things: 1. Make sure the bottom rod is pushed in. 2. Holding the gun by the handle on the top left of the gun, below the hose there is a little metal valve. Push that vent valve down and pull the trigger repeatedly until grease starts to come out.
If that doesn't work. Remove the grease hose, hold the vent valve down, pull the trigger a few times. Then release the valve and pull the trigger until grease comes out. Replace the hose.
And if that doesn't work. Sometimes when you put in a new cartridge the metal "washer" that actually pushes the grease up the cylinder will get caught at the bottom of the new cartridge. Make sure the washer will move freely into the cartridge.
That should do it!
Jan 14, 2011 | Lincoln Automotive Pneumatic Grease Gun...
Machine leaks grease like substance at in the bottom of drum during spin cycle sometimes
The transmission is leaking grease because it's worn the seals out. The seals can be replaced or the transmission can be replaced.
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Feb 26, 2010 | Speed Queen Washing Machines
My washer keeps leaking grease onto my clothes!
the problem that you have is the bearings have badly worn,a lot of companys will just replace the entire drum rather than mess about with the bearings as this does not always solve the problem.sorry to give this bad news.
Jul 15, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Kenmore 22642 Top Load Washer Logo
228 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
