Question about Bose in-ear headphones - Black with black/white cord
Hi, I have a concern for my in-earphones as the cord looks to be damaged. I need to replace the cord.
    Brigadier General:
  • 3,006 Answers
You cannot replace the cord. If the cord no longer functions correctly then the only fix is to replace the entire earphone, but if the cord still functions then you may wish to wrap a little electricians tape around the damage or to apply heat shrink tubing over it.
Posted on Aug 04, 2010
My ipod plays songs and i can hear the music but when i switch to radio there is no sound speakers do not work on radio..what is wrong????
Hi Fay
You need to clarify what you are saying....
Your iPod plays songs and you can hear music?
Where is sound coming from... Earphones?
How do you switch iPod to Radio....
Is there a cord connecting both together?
I would then suspect cord or connector type not matching up with radio input connector.
Connectors can be Sterio or Mono
Look at spacing on connector....
Earphone Adapter may help here
Mar 03, 2015 | Audio Players & Recorders
My 6133 is barely audible on headset speaker. Works fine on loudspeaker.
hi there!
there's a huge chance that the headset that you have is already damaged. either its speakers or its cord. try using other headset, if the problem is the same, it can be the headset port (where you insert the headset jack). try moving it while its plugged see if the sound changes. if its the headset, replace it, if its not, bring the phone to a local technician so that they can replace the earphone slot. =)
Apr 09, 2011 | Nokia Cell Phones
I can't get sound to come out of the right earphone
Hi. Try to check if it is properly connected to the sound source. If it is, check for the wires. Look for damaged parts especially near the ends. If all these look fine then the earphone speaker itself is defective and that means you need a new pair.
Feb 04, 2011 | ifrogz EarPollution Plugz Headphones
I have used corded earphone while I was on travel. After unpluging the earphone, The phone does not work even with blue tooth. ( no dialing tone, no sound at all) I can used it only with corded...
hi sfkimura you need to take the battery out of the phone. Next plug the headset and into the port. Take the headset out and now put the battery back into the phone. the phone got set in headset mode. You can try doing a reset of the default settings. Don 't do a factory reset it will erase your phone back to nothing on the phone. Ok hope this help
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Jan 19, 2011 | LG Dare VX9700 Cell Phone
Hi the wire has frayed and is exposed at the entry point into the earphones to My 5 Series Shure earphones. One earphone no longer works. Can this be rectified? Regards, Robert....
hi,you can fix it by opening the ear that is not working and check if the wire inside the earphone has not removed. If it has removed, you can use a soldering iron and a lead to fix it back.
But if the wire inside has not removed,that means the speaker inside is damaged and will need to be replaced.
In replacing the damaged speaker, you will need to go to any nearby repair store for replacement parts .
If you can not get a replacement speaker,you will have to get a new one.
And for the exposed wire,you can use a gum or a glue to cover it up...
Hope it helps..
Thanks for using fixya.....
Jan 06, 2011 | Shure E500PTH Professional Headphones
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
Apple Ipod 4th Generation is only playing music through left ear jack. I'm confident it is a earphone/jack replacement issue. The problem occured when someone yanked my ipod from me and the ear bud cord...
Well, yes you are right there is no other issue than earphone. you can purchase the earphone from the below link -
http://cgi.ebay.com/ORIGINAL-Apple-4Gen-Earphones-Headphones-for-All-iPod_W0QQitemZ260523098037QQcmdZViewItemQQimsxZ20091214?IMSfp=TL091214234010r19836
Good Luck!!
Thanks
Jan 06, 2010 | Audio Players & Recorders
Telex-#59840006-replacement cushions for AAR-10 earphone
Try this site, 15th item down. http://www.bhphotovideo.com/bnh/controller/home?A=search&ci=9724&Q=&O=NavBar
Nov 29, 2006 | Telex Replacement Cord (591187-001)...
Bose  in-ear headphones - Black with black/white cord Logo
505 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
