Sir, usb device software not install properly and usb device not reconized. and error code 43
    President:
  • 2,340 Answers
If yours is a laptop or notebook, try this:-
Turned the laptop off, unplugged it, and pulled out the battery for a few minutes. Then rebooted.
Posted on Aug 04, 2010
How Do I Fix Error Code 43 in Windows 7?
This is probably one of the most frustrating and "generic" error codes reported by Windows. When I say "generic", I'm referring to the fact that Windows is basically telling you that a hardware device on your PC is well... not working. (Gee, Thanks!)
Error code 43 is reported anytime Windows does not recognize a device - whether it be a USB port, Hard drive, video card or any other piece of hardware connected to your computer.
You will usually see an error message like this:
"Error Code 43: Windows has stopped this device because it has reported problems"
And if you look at the hardware under Windows device manager, you will see something like this:
NOTE: The hardware device above is only an example. It could be any device on your computer that is reporting error 43.
What Causes Error 43? 95% of the time, error code 43 means that a device driver is either missing, corrupt, outdated (so Windows problems communicating properly with the hardware), or the hardware is faulty and needs to be replaced.
Device drivers can become damaged or corrupt over time, and most users will eventually experience a driver error. Installing and removing software and hardware can cause conflicts in the registry and can alter driver communication.
Sometimes you can bypass the error temporarily such as removing the device from the motherboard and reseating it, removing the power cord from the power supply and restarting your computer after a few minutes, etc. However, theses are temporary and will not fix the actual problem.
Solution For Fixing Error Code 43 Messages The first thing of course is to make sure your device driver is up to date. I have provided two ways to accomplish this below:
Option #1: Update your drivers automatically (the easy way)
If your not that technical and don't want to hassle with trying to locate the correct device drivers from your PC's manufacturer and then go through the process of uninstalling and re-installing your drivers manually, then you should run a free scan with a recommended driver tool.
This software will match and download the correct drivers you need. It's safe and saves a lot of time keeping your PC updated.
Option #2: Update your drivers manually (the technical way)
If you consider yourself pretty technical and feel confident making changes to your system, then follow the steps below:
Step #1 - Uninstall the current driver:
First, you need to uninstall the current driver...
  • Click "Start > Run" and type "sysdm.cpl" in the text box and press ENTER
  • Open the "Hardware" tab on the System Properties dialog box, then click on "Device Manager"
  • Double click "Device Type", then click on the hardware device that is reporting Error 43
  • Next, go to the "Driver" tab and click "Uninstall" to uninstall the device driver completely
Step #2 - Locate the correct driver:
After you have uninstalled the driver, visit the manufacturers website and locate the newest driver for your device. You can usually find the latest driver under the technical support or driver section of the company's website.
Step #3 - Download the driver:
Download the driver and save it to your computer. It will most likely be compressed in a .ZIP file, or an executable file (.EXE).
Step #4 - Install the new driver on your PC:
Extract the .ZIP file or double-click the .EXE and install the driver.
Step #5 - Reboot your PC:
If you uninstalled the old driver and installed the correct new driver, it should fix the communication problem between Windows and your hardware device, eliminating the error 43 message. If not, you might want to install the faulty device on another PC and see if it works correctly.
If you continue to experience problems then most likely the device itself is damaged and needs to be replaced.
Good luck.
Semper Fi,
Z
Feb 19, 2018 | Computers & Internet
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
Windows has stopped this device because it has reported problems. (Code 43)
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
Oct 05, 2013 | Nokia 6230i USB
P5n-e sli usb ports error 43
You get this error code if there is an issue with the drivers.
Look here:
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/usb-ports-not-working-error-code-43/ce6662bf-cfad-4380-a274-709bf072e3d7
Here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N-E%20SLI&p=1&s=22
Please select your windows system.
You probably need to download the chipset driver.
Open the folder, and click on global for download.
Unzip the file before you install the driver.
Look also in the bios setup, for the usb settings.
Try also to download the manual.
Try also to upgrade the bios.
Hope this will help you
Jan 31, 2013 | ASUS P5N-E SLI Motherboard
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I have windows 7 and wants to install hp psc 1310 but facing code 43
you probably have the wrong driver installed. Most likely you have upgraded to a 64 bit system, and the driver is 32 bit. Find out which system you're running (right click 'computer' and click 'properties').Disconnect the printer and Uninstall the software, then go to hp website and download the proper software and install here:
May 13, 2012 | HP PSC 1315 All-In-One InkJet Printer
How can I resolve an erreo cod 43?
First, please disconnect all USB devices and then perform the following steps:
Using the mouse;
1. Click "Start" button, type “devmgmt.msc” (without quotes) in the “Search” bar and press "Enter". Click “Continue” if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Using the keyboard;
Again, disconnecting all USB devices
1. Press "Ctrl + Esc" to open the “Start” menu.
2. Type “devmgmt.msc” in the Search bar and press "Enter". Click “Continue” if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
May 29, 2010 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
