Question about Black & Decker BL550 ProBlend Work Top Blender
Black & Decker blender BL1900/550W, 120V-60HZ,27FM Lost the rubber/plastic seal to bottom blade that keeps it from leaking. Need replacement grey ring seal. Where can I get one in Raleigh, NC 27614 or can I order the part? Nancy Petty-919-847-0966
My B
Posted on Sep 06, 2010
I have an older Waring blender, model WF1112218. My problem is I took it apart to clean it and now can't figure out how it goes back together. Is it rubber gasket then rotor or the other way around?
Hello, Carla -
For all electric blenders the rubber gasket is placed between the glass or plastic blender container and the rotor with the blades.
The assembly is easy to recall when one realizes the rubber gasket is the seal for keeping liquids leaking out of the blender.
See the image here (it's for a Black and Decker, but the assembly is the same):
http://stainless-steel.us/12-pictures-of-baby-bullet-blender-instructions/black-and-decker-blender-assembly-instructions/
The image here shows the assembly for a Waring blender (different model than yours):
https://www.etundra.com/restaurant-parts/parts-diagrams/waring-bb140-bb150-bb240-bb250-bar-blender-parts/
Best wishes.
Jun 01, 2018 | Waring Blenders
Sj9668, blender is leaking from bottom. I think i could go to the store and ask for a gasket? What would be the name of the piece to go inbetween the blades and the bottom hardware? slightly lose.
Most blenders have similar issues and it occurs when you have a binding and the seal gets hot and the rubber wears away.
in this photo I replaced this part it was only 9.98 on Amazon.
But it was for a black and decker. Because you mentioned the blade felt loose I would try that.
search Amazon for blender parts, maybe use model number of your blender. But save picture to phone and then you have idea what you might need.
Oct 26, 2016 | Blenders
My glass jar leaks from the bottom
remove the screw on blade holder, and make sure the gasket is in place ,, check the seal on it,, if its defective replace it,, check along the threads to make sure that the canister isn't cracked
Aug 28, 2011 | Black & Decker BL1900 5-Speed Blender
We have a Black & Decker BL9000 blender. On top of the base, there is a plastic disc that meshes with the bottom of the jar and drives the blades. I think one of the kids was making smoothies and...
Available replacement parts can be found here:
http://www.directpartsandproducts.com/blenders-bl9000-c-1_4_60.html
or here:
http://www.abtecparts.com/Black_&_Decker_blenders_BL5000BL6000.htm
I have not seen the drive gear made available. You could try making an inquiry with either of the above sites to see if they can locate a replacement. Alternatively contact a local small appliance repair shop; they may be able to scavenge the part from another blender.
May 16, 2011 | Black & Decker BL9000 Blender
`my blender leaks out the things i put in it
The seal on the rotating shaft has either worn out or hardened and if constructed like most, the seal cannot be replaced since the chopping blade and shaft are permanently fastened together. Your only recourse is to buy a new blade assembly which should be available.
I would search for it with the model number of the blender and 'cutter' or 'blade' assembly.
Jun 16, 2010 | Black & Decker BL600 ProBlend Work Top...
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
Replacement parts
My blade assembly leaks just as you are describing. I found a website that offers replacement parts for Black and Decker appliances:
[Note: I have not ordered from this site yet so I can't say how reputable they are.]
They offer the glass jar, blade assembly, and other parts for the BL1900R. Judging from reviews, it may not be long until something else goes wrong.. I am gong to order the replacement part this one time. If anything else goes wrong though, forget it. Too bad. Black and Decker usually makes good stuff.
Jan 04, 2008 | Black & Decker BL1900R Blender
HB model 52735C type B35..intructions for blender pls
go to hamilton beach .com with model and serial no down load a book
Dec 31, 2007 | Blenders
Black & Decker BL550 ProBlend Work Top Blender Logo
467 people viewed this question
Top Black & Decker Blenders Experts
Marvin
Marvin
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
