Question about Microwave Ovens
Looking for new popcorn "pot" for Modal Medal MEA 23-87-E
How to pop popcorn
place a teaspoon of cooking oil in the pot and place on stove. Put a small amount of corn to be popped in the pot and the heat will do the rest. 1/4 cup of corn will probably overflow the pot so use small amounts first until you get the idea.
Feb 05, 2015 | Panasonic Inverter Countertop Microwave
Microwave popcorn
Could be your KitchenAid microwave only works with bagged popcorn.
Jan 22, 2014 | KitchenAid Microwave Ovens
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
Can you oil or butter in with popaire 2,
(BUTTER chamber thing) The little rectangular scooper-looking thing on the slope of the top is where you can put a chunk of butter that will melt from the hot air and drizzle into the popcorn popper as the popcorn is popping. My dad said you cant use oil in it
May 02, 2011 | Microwave Ovens
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Bright flash inside microwave
try a different brand of popcorn & let me no what happens
May 12, 2008 | GE JES1290 Convection/Microwave Oven
Will not pop popcorn without burning it
use Orville Rickenbacker ah you know who lol set it for five minutes when you hear it slow take it out works for me no the oven don't need repair popcorn's tough the best way i know to make popcorn is an electric skillet yum yum
Feb 16, 2008 | GE JEM31 Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
