Question about Kenmore 24032\24036 Top Load Washer
My washer machine drum fell off its track. how do i fix it?
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: the washer fell off track, and i dont know how to open it up
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
10. Uninstall the motor mounting plate from the gearcase by removing the two bolts.
11. Remove the agitator by removing the center cap. Locate the center nut under the cap and loosen with a socket and ratchet. Lift both portions of the agitator straight up, exposing the gearcase center shaft. Remove the agitator clip and agitator washer from the shaft. NOTE: If there is a recessed square slot under the agitator cap, use a 3/8 inch to ½ inch socket adapter with extender to remove.
12. Now take the washer and lean it backwards so that you have full access to underside of the washer. Loosen the three bolts holding the gearcase in place. When you get the last bolt, loosen slowly as the gearcase will begin to drop from under the washer. Slide the entire gearcase and shaft out of the washer.
13. Remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip. Do not forget to retain the washer that is under the clutch.
14. Inspect new gearcase assembly. Open the breather hole (covered by a dab of paint) using an awl or similar tool. Install washer on gearcase shaft and install clutch and brake assembly. Slide gearcase shaft up through the agitator shaft from under the washer. Hold in place and get one bolt started. Insert remaining bolts and tighten them all evenly.
15. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
16. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
17. Reinstall electrical connector to the Drive Motor.
18. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
19. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
20. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
21. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
22. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
23. Reinstall console.
It seems like a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information helpful.
NOTE: Under Line Item 10. - after you remove the motor mounting plate, make sure you disconnect the wiring harness from the the gearcase housing if it is mounted to it. Otherwise, you may damage the harness when you remove the gearcase assembly. Make sure you re-install the wiring harness in the fashion when repairs are completed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
As soon as i turn my washer on it just makes a loud grinding kinda noise how do i fix?
If the machine was delivered new, has all the transit straps been removed ? If the machine was delivered without transit straps then the drum could be off a support and it's drum wheel could be grinding on the rear panel.
Oct 04, 2014 | Maytag Atlantis MAV6451 Top Load Washer
Screws fell out on the drum assembly and now there's no heat
good because you could have a fire if it actually worked... really
Dec 29, 2013 | GE Spacemaker Washer and Dryer Electric...
My dryer sounds like my washer agitating off track
Your drum has disconnected from the rail in the dryer. Sometime a bolt can work its way out and the drun can get off track. Remove back of dryer and see if you can get the drum on its track and see if you can find the reason why it came off.
Oct 15, 2013 | Kenmore HE2 Plus Front Load Washer
I have a kenmore front load washer model 41744042400 the drum seems to be off its track. it makes a lot of noise when spinning and shakes a lot. One of the shock absorters was broken and i replaced it....
they dont have tracks they sought of float in the middle of the tub held on by the shaft coming off the spider arm on the back of your drum, if you can move the drum back and forth and it makes a metal crunchy kinda noise your spider arm has snapped to fix it you need a new drum and will almost quite literally have to dissasemble the machine into every piece its made of, altho not neccesarily difficult is quite time cosuming about 3-4 hours (thats for someone with experience)
Sep 20, 2010 | Kenmore Front Load Washer
The drum fell out of the socket and unable to spin at super fast speed, so the extract cycle/final spin does not fully extract the water. is it worth getting this fixed or should i just buy a new washer?
If you turn the inner drum by hand and if you hear thumping noises as it turns or it does not turn smoothly. The problem is probally a broken spider or support arms. It is very expensive to repair, costing as much as a new washer.
Jul 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer bangs loudly on spin cycle
if you look inside at the top of the inner drum there are two big springs and a bamper at the bottom if any of the springs have snaped or just fell off there not holding the drum up and this is why it makes all that noise
its best to get it fixed as fast as you can as when its spinning the drum is wacking about inside your washer and its going to smash its self to bits as well as rip all the water pipes and wireing off as well?????
its an easy fix if you can do it?????
May 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LG front load washer A coin fell in between drum and housing.coin rubs on drum while spinning. how do you access the area between the drum and housing?
take off the front panel
on the bottom/front of the drum is the heater- held in with 10 mm nut - slacken the nut- this will loosen the heater in its holder- pull out the heater- this gives you access to the bottom of the tank
Jul 16, 2009 | LG WM-2277HW Front Load Washer
Stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Mar 04, 2009 | LG WFT1071TP Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
6,590 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
