Question about Dryers
On my early 1980s GE gas dryer Model #DDG7188PHLWH the push/start button does not work. It will start but will not "stay started" -- you have to hold it and even then it cycles on and off. Can this switch be replaced, and if so how much [expensive] dismantling of the dryer control panel would be involved?
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
agitateme
  • 88 Answers
SOURCE: Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Posted on Jan 17, 2008
  • 31 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Your motor has fried. It isn't in the Control Panel, the SENSES light wouldn't turn on if it were the CP. If you go to your closest Home Depot, ask the front desk for assistance with Dryer Motors. They will guide you through to get you the right one. They will even tell you how to install it. When you replace it with the new motor, the Dryer will work fine.
If this helps at all, please rate this a FixYa. - Evolution
Posted on Jul 17, 2008
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Does a ge gas dryer with the model number DBSR453GBOWW have a pilot light?
Your GE dryer does not have a pilot light, a common issue on gas dryers is the ignitor. More info needed (what does the dryer do or not do when you push the start button?) to give a better answer.
Feb 12, 2015 | GE Dryers
I have an older GE Profile gas dryer model Cthat I replaced the belt on. Now when I Turn the start button it turns on, the drum turns but i don't think the ignitor is igniting. It stays on as long
Well if it runs but no heat it might be the solenoids. All these dryers basically have the same gas assembly. If your ignitor comes on and shuts back down it should fire off . if it don't then them coils is probably bad:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2012 | Dryers
How do you light a pilot light for my GE gas dryer? Model = DDG7188PHLWH
How old is your dryer? Only models from the 1980's and older have actual pilot flame lighters. If it's newer it will have either a spark igniter or an electric glow bar. If you have a large front access panel across the bottom, then you may have a pilot light. Remove the panel and look for the gas valve. (NOTE: Before lighting anything, make sure you do not smell gas. If you do, you'll need to air the room out before trying) There will be a burner coming out the back of the gas valve control and this control will have a red push button in the front or side of it to allow gas to the pilot only. Using a extended bbq type lighter, light the pilot at the pilot assembly and hold the button for about 60 seconds. The pilot assembly is connected to the gas valve control by a small diameter aluminum tubing with a copper thermocouple right next to it. Release and make sure the pilot stays lit. Before putting the access panel back on, turn on the dryer and watch for the burner to light. It should be a strong blue flame. Let us know if we can help you further. Not knowing why your pilot went out in the first place, there may be a unforeseen issue that may need attention. If you have a propane gas dryer and you ran out of gas, then it may take a while to get gas to the pilot, so be patient when trying to light it. Never hold the button down without the lighter lit at the pilot assembly, so there is not a build-up of gas. If you are not comfortable doing this, I recommend you call your gas co to light it for you, as many will do it for free! Good luck and be careful!
May 20, 2010 | GE Dryers
Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
May 07, 2009 | General Electric DCVH640GJ Gas Dryer
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Dryers Logo
88 people viewed this question
Top Dryers Experts
Marvin
Marvin
