Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
I brought new wireless router G ADSL2 4 PORT ROUTER but i dont know how to fix
  • 4,281 Answers
Configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 04, 2010
Hi ive just brought a new samsung led tv with wi fi and iam tying to connect it via my belkin 54g wireless router but the tv can not find the router can u help help help plse......
hi,
i think you had better to see this link : here
because i dont know what OS you are using ?
you don,t describe how you are setting the router with your PC or TV ?
so refer to above link , hope to find ano solve the problem.
good luck
gorbesia
Jun 14, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Hi got this problem with my new linksys dual-band wireless-N gigabit router. I dont know how to set up. Please help me.
To install that router is the same as any other linksys routers. Check this link http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=9017a6f6bece444dbb4a0746eb87682a_2210.xml&pid=96&slnid=10
Mar 18, 2011 | Linksys Dual-Band Wireless-N Gigabit...
I am trying to add a new mac ip address to my wireless router i started with 1 pc then brought a laptop and a wireless d-link router they work fine i just brought home another pc it has a card put through...
Please follow the steps mentioned below on the Computer where the internet connection is working normally and check if the issue is resolved.
  • Please type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
  • Please Use "Admin" as the user name and leave the password blank when the login screen appears.
  • Please click on Wireless, enter the Wireless SSID name (name for the Network) and under Security, select the Security type and type the Security Key.
  • Save the settings and try to connect to Wireless on the Computer having the issue.
  • It will ask for the Security Key, enter the Security Key provided during the Wireless setup.
This should resolve the issue.
If the issue is not resolved, reset the Router to factory settings and then try connecting.
Please try to locate the Reset button near the Ethernet ports and press for 10 seconds.
Good Luck!!!!
Please let me know if you require further assistance.
Thank you for contacting.
Jun 23, 2010 | D-Link SWT DSL-504T ADSL MODEM with 4...
How to fix D-Link ?
192.168.0.1 in address bar admin password is admin leave username blank. setup-wireless see what mac is shown if different change here save settings
Apr 07, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
I'm trying to connect to routers together from one house to another house
Hi, i don't know if you have sorted it out, but i dont think you can do it, I think you are better of buying an 8/16 port switch.
But let me know if you have fixed it.
Regards - Anthony
Jan 28, 2010 | Linksys WRT160N Wireless Router
Nat settings on a linksys wireless router
NAT Configuration is also called Port Forwarding. You can simply open the ports by going to the router's setup page http://192.168.1.1 no username and password is admin. You can do it under Applications and Gaming tab, Port Range Forwarding.
Jun 20, 2009 | Linksys Wireless-G Broadband Router
Want to add port for utoorrent,also how to fix nat problem
If you are running a router (sometimes called wireless access point) at home, you will have to configure it to route all TCP / UDP BitTorrent traffic to port 55641 to your computer.When the router asks for a range of ports to forward, simply specify 55641 to 55641.It would be beneficial if you can let me know the type of router you are using so that i can provide step to step solution.
Apr 08, 2009 | Linksys WRT160N Wireless Router
Wireless adpater red!
try using WEP encryption, especially if you use a G router, as thid is easier for the adapter to work with then WPA. also make sure that you have the ports open for xbox Live, i think its ports 88 and 3074
Jun 30, 2008 | Microsoft Wireless Network Adapter Xbox...
I dont know the correct way to hook up my cable modem, computer, and wireless router together
hello!
-- is this a brand new router?
-- who is your internet service provider?
-- what is the brand of your modem?
-- what is the operating system of your compter
you may try the basic connection:
-- while the router is powered on, reset the router for 10 secs
-- turn off your modem, router and computer
-- from the ethernet port of your modem, to the internet or wan port of your router
-- from one of the regular port of your router to the ethernet card of your computer
-- turn on the modem first, after 5 secs, turn on the router, another 5 sec turn on your pc and check if you can get online
May 01, 2008 | Linksys Wireless-G WRT54G Router
Problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
  1. Open your browser.
  2. Type in this ip address - http://192.168.1.1
  3. Configure the router as you see fit. It's fairly simple and has built in help guides.
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
  1. WAN port directly to cable/dsl modem.
  2. Any port (1-4) running out to your computer.
Please let me know if this helps. Good luck!
Feb 24, 2008 | NetGear WGR614 Wireless Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
174 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
