My parents have a WD52527 and the picture has gotten darker over time. They are relatively heavy smokers and that's likely the problem. We've cleaned the mirror and the lens (the one immediately before the mirror) several times and it helps but the picture has gotten progressively darker. A new bulb didn't make a difference.
Does anyone know if the light engine is sealed to prevent smoke from entering?
If it's not sealed, its optics are probably coated with smoke. Does anyone know if it's possible to disassemble and clean the lenses, mirrors and LCD panels?
Is the light engine available as a replacement part? I haven't been able to find it on the net. The part number is: 938P015010
You have to be careful when replacing the projection bulb assembly. Don't aways look for the cheapest as they are rip-offs that do not last long and are not as bright. Dont buy OEM "compatible" only OEM originals. Call Mits Customer Service for advice
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WD52527 52 in. HDTV
Just got a new bulb for our mitsubishi wd-52527 and not sure how the wire that holds the bulb into...
(More)
Just got a new bulb for our mitsubishi wd-52527 and not sure how the wire that holds the bulb into the housing is supposed to go.
I have a new HDMI cable for my ps3 but once i set the setting for the ps3 to use the HDMI i get no...
(More)
I have a new HDMI cable for my ps3 but once i set the setting for the ps3 to use the HDMI i get no picture and no sound. The cable is plugged into the hdmi port on the ps3 and on the tv itself. Following the HDMI directions I disconnected the standard cables (red white yellow) but I get no picture and no sound. I also have no remote so is there a way to set the tv to hdmi without a remote?
I have the mitsubishi WD5257 HDTV. My problem is that the TV is not recognizing any of the devices...
(More)
I have the mitsubishi WD5257 HDTV. My problem is that the TV is not recognizing any of the devices that are setup in the device menu - stuck on a blue screen - HELP
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
