Question about PayPal Accounts
I have been overcharged - how do I resolve this ?
    Problem Solver:
  • 42 Answers
You can ask the seller for partial refund
Posted on Sep 14, 2010
What problems can occur when you overcharge the hvac
The level of overcharge will dictate the severity of the possible problems. The most common problem with overcharging is creating high compressor head pressure which over-amps the compressor motor which waste energy and shortens compressor life. Installed high pressure safeties will usually shut off the unit off and must be manually reset. High system pressure also results in higher evaporator temperatures and higher air discharge temperatures. Grossly overcharged systems could return liquid to the compressor, destroying it.
Sep 04, 2014 | Heating & Cooling
Keyless entry fob stopped working for 2007 montana
I found the issue, To be some Idevices incorrectly measure the remaining amount battery life .. So the device drops below .25v 10mah , as stated in previous comments well below the idevice to enable to charge circuit , its similar to how the voltage regulator work in a cars alternator which needs power eg.
its not the best way the resolve it .. but it works and add near no additional strain to circuit ... i recommend to unplug from charger when bat reaches 100% ... to stop overcharging ...
http://www.xcardiag.com/
May 21, 2014 | 2007 Pontiac Montana
R22 need diagnosis please
It could mean you are overcharged and that somone tried to resolve the real problem by adding refrigerant (R22).
Dec 11, 2013 | Heating & Cooling
Dell error 2000-0221
when are you getting this error?? while opening any application or when starting the laptop..?
Sep 09, 2013 | Dell Computers & Internet
How to save from battery overcharge
Most laptops(newer ones) have technology in them that will prevent any type of overcharge. If you are weary or it is an older laptop you can unplug it once its fully charged and that will avoid any problems with overcharging.
Jun 08, 2013 | Computers & Internet
Mitsubishi L200 alternator over charging
The alternator produces current but it is also accompanied by a voltage regulator circuit to prevent overcharging. That is the area that needs addressing to resolve your anomaly.
May 10, 2012 | Mitsubishi L200 Cars & Trucks
Put a new alernater an still over charging
Over charging could be the result of several things including:
    Faulty Voltage Regulator
  1. A car's battery will overcharge if the voltage regulator isn't working correctly. A voltage regulator is usually part of the alternator, and is used to keep a steady flow of voltage to the battery. If the voltage regulator is defective, it will send either too little or too much charge to the battery. If it sends too much, the car battery will overcharge. The voltage regulator is easily replaceable at an easily affordable price, sometimes for as little as twenty dollars, as of 2009.
  2. Faulty Alternator
  3. Sometimes the alternator itself can be at fault. The alternator is the device that converts the mechanical power of the engine into electrical power to charge the battery. When an alternator breaks, it usually stops creating electricity for the battery, which will then eventually die. However, if the wrong alternator is placed in the car, or if the alternator is running at the wrong pace, it will create too much energy for the car battery, causing it to overcharge. The alternator is another easily replaced part.
  4. Incorrect Charger Use
  5. If a battery charger is used to charge your battery outside of your car, improper use of the charger can result in overcharging. If a battery is placed on the charger too long, it can result in overcharging, and a significant decrease in your battery's lifespan and efficiency. This is why it is important to read about your specific battery and understand how long it needs to charge to be effective. Too much charge will lead to problems.
  6. Faulty Battery Chargers
  7. Sometimes chargers can be faulty. Their settings may be wired incorrectly, or the charges labeled incorrectly. As a result, your battery may be getting overcharged, even if you are carefully monitoring your charging. This is a problem that is hard to avoid, as manufacturing mistakes can happen anywhere, anytime without warning. It is a good idea to test your charger regularly to see if it is running correctly.
  8. Heat
  9. Extreme heat in the summer can also have an adverse effect on the car battery. If the battery has been previously overcharged, extreme heat can increase the problems caused by overcharging, and exacerbate any other problems with the battery. This problem can be hard to avoid if you live in a warm climate. The only real way to ensure safety against this problem is to avoid overcharge in the first place.
Feb 27, 2011 | Ford Expedition Cars & Trucks
Battery overcharges and light is on
Never saw a charging system problem cause anyone to fail inspection. But, overcharging will cook the water out of your battery and can damage the computer system if not taken care of. Overcharge can be caused by either a grounded alternator field wire or a bad regulator. Since the condition appeared after replacing the alternator it too is suspect as an internal grounding can also cause that.
Jul 20, 2009 | 2003 Ford Focus
Overcharging celfone
I would suggest replacing the battery and try not to overcharge the new one
Nov 29, 2007 | Motorola Mobility RAZR V3
PayPal Accounts Logo
22 people viewed this question
Top PayPal Computers & Internet Experts
LP
ROBO50
Mike
Are you a PayPal Computer and Internet Expert? Answer questions, earn points and help others
