Question about Cell Phones
When i switch on my cel then after a few a second it will be switched off. then how n i solve this problem.i guess it will be virous problem.
    President:
  • 1,469 Answers
Hi, when a phone won't turn on and blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Posted on Aug 04, 2010
Will not start cold without a lot of tries runs fine warm?
the first sidekick ever. 1989. (and tracker)
the first few were made in Iwata japan then at CAMI (canada) then on.
first off this year, came with 2 engines, 1.3L carb and 1.6L TBI EFI.
so what engine? we can NEVER guess and engine, blind.
The CEL if a CEL , and TBI 1.6L engine G16A
that lamp can glow for 2 reasons in 1989-95.
Check engine. function
and what we call the NAG lamp.
http://www.fixkick.com/CEL/NAG-Lamp.html
the nag switch is hidden in 3 locations in 7 year span.
its just to make folks angry.... (Hiroshima>? revenge?)
on this car, if it has a NAG it on the bottom kick panel
between your legs, (toes)
and can never be seen. only felt (lacking a mirror)
NAG = federal (usa) mileage warning see if leaded fuel messed up the CAT ,deal,, (totally useless now)
We remove them at the cluster 3 wire connector forever.
so if present slide the switch 1 time.
now the CEL lamp can flash out flash codes.
http://www.fixkick.com/CEL/CEL.html
hard cold starts, if CEL flashes 12s does it?
causes (top, not a guess) I do tests to find these but takes TOOLS.
  1. never tuned up with all new spark parts and filters.
  2. cam belt slipped. (60k part)
  3. engine is flooding, high fuel pressure, (too high)
  4. TBI injector o-ring leaking. flooding starts.
  5. ECT wires fell off.
  6. map hoses bad. or clogged end to end. from plenum to map sensor insides (nipple not clogged either)
  7. not melted cat, runs fine hot.
  8. not code 12s flashing (good) so what is it flashing. ?
  9. stuck open EGR main, (that can bounce closed as you crank long then be ok... for a while, many old EGR like to stick just as you stop car and shut down) can be felt by hand on any 8v engine easy. the diaphram ring can be exercised with fingers.
  10. IAC bad, stuck closed, preventing cold start air . and flooding.
  11. ISC valve same.
  12. Dash pot valve stuck retracted. (clod start vacuum start)
  13. spark timed wrong , see cam belt slip.
Nov 06, 2015 | 1989 Suzuki Sidekick
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
Solid check engine light
Disconnect the battery negative cable and re-connect after 5 minutes. Turn the ignition switch ON and wait for few seconds to let the CEL turn OFF automatically. I would diagnose the codes though, if the CEL is blinking frequently.
May 06, 2013 | Lincoln Mark VIII Cars & Trucks
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My phone is not geting switched on.is virous has affected its driver???
hi.. yes it is a virus problem... try to format ur mobile... it will reset ur mobile and will be freed from virus...
thank u
rate me
May 24, 2009 | Motorola Mobility SLVR L7 Cellular Phone
1998 Nissan Cefiro engine turns over but stop after few seconds,
I already solve the problem by just having the car key reprogrammed
Mar 19, 2009 | 2000 Lincoln LS
Automatically restart mobile sgh j210.
your mobile is virous effected . So you can go to the mobile hardware point and solve it .
Mar 06, 2009 | Cell Phones
Reset check engine light
First of all, you should'nt do this unless you know what the problem is.. or what tripped it. I had this problem when my husband and I were replacing a head unit and disconnected the old head unit, a/c and other stuff then turn the car on. This made the light flash. The first time we took it in and got charged $50 to reset it. The second time we did this procedure and it worked.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Reset Check Engine Light Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
-Christine
May 15, 2008 | 2007 Nissan Murano SE
Nokia 6030 - Couldn't switch on the mobile
hi dude,
i think its a problem with ur power switch, or rubber inside it !
Check it out .. I think it dont cost to check it !!! It dont cost too much also to repair it !
send me a feedback and rate my solution.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 13, 2008 | Nokia 6030 Cellular Phone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
