Question about GE Refrigerators
The ice dispenser on the freezer door is making a very loud humming sound. If the door is opened it stops. I cant leave it open because all food would be destroyed. What can I do?
    Brigadier General:
  • 3,513 Answers
Hi
Check to see if bottom freezer has not iced over, the back panel at rear of freezer has a small fan in it to circulate air and if the freezer coil in frozen /iced over the fan will hit the coil making loud noise. Fan is supposed to stop when the door is opened . Noise from the fan could be a bearing problem if it is a high pitched squeal. If this is the condition you have, replacing the evaporator fan should correct the problem. If the fan is sounding like a buzz-saw the fan blade could be pushed in to far on its shaft or it could be hitting an ice build-up in the blade turning area.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
We have a Samsung Model number RS2530BBP that the freezer is making a loud buzzing noise. It only stops when you open the freezer door.
It sounds like the solenoid which opens the ice dispenser door or works the cubed/crushed ice part of the ice dispenser is stuck. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Check you model number as that one doesn't match any. Here are some close matches. http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RS2530BBP
You can see diagrams of yours if you find it.
Nov 30, 2010 | Samsung Refrigerators
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Both the refrigerator and freezer are set to the recommended temperature, however, the refrig unit is making a loud humming sound. This sound stops when you open the door, but begins again when it is...
There is a fan that blows cold air into the refrigerator. It usually stops when the door is opened. Check to see if it might be frozen with ice if the humming sounds abnormally loud. Usually if it freezes up you cannot hear the fan running and the refrigerator will not get cold enough.
Aug 25, 2009 | Refrigerators
Refrigerator side only cooling to 55 degrees. turned off frig for 7 hours after removing all food and leaving doors open for any ice build up to melt.
do you ;here or feel the freezer fan working and or humming if when you open the door fan stops hold the door light switch by hand to do the same or do you hear a hum and click from behing and rear of the frig if so compressor having trouble starting
Aug 22, 2009 | Whirlpool Refrigerators
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
