Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Power to refrig. Front displays show temp for freezer (0) and refrig.(37). Fan running by coils. Neither will cool. Also the compressor is hot but no humming or other noise
  • 4,070 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Aug 04, 2010
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
The divider between fridge and freezer is very hot. How can it be cooled down
Clean the coils at the bottom front , behind the bottom kick plate AND pull the refrig out and remove the panel covering the compressor . Once removed , check that the cooling fan ( condensor fan motor ) is not blocked and is running as the compressor runs .
Sep 27, 2010 | Refrigerators
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
Maytag side by side issue: Refrig works normal. However the freezer defrosted itself, food is thawed. I'd like to repair myself, what's your recommendation i.e. troubleshoot, what to look for prior to...
Pull the refrig out , and remove the back panel . Is the compressor running ? Is it hot ? Is the fan cooling the compressor , running ? If the compressor is not running , the piece on the side , with 2 or 3 wires going to it , is bad . If the fan is not running , replace the fan motor . The part number for the compressor piece ( overload/relay kit ) is 12002784 . It is easily replaceable . If the compressor is running , check the square black coil box ( condensor coil ) , to make sure it is clean . Is clean , check the fan in the freezer , to make sure it is working .
Nov 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
The panel between the freezer and refrigerator heats up - too hot to touch for a while then cools off again. GD5SHAXLT01
You need to clean the coils under the front of the refrig of dust , lint , pet hair , etc . Pull the refrig out and remove the back panel covering the compressor . Make sure the fan there , next to the compressor is working . Usually , if this fan is not working , the center strip gets very hot , and the compressor may cut off , from getting too hot . The compressor can burn out , if the fan doesn't work for a while .
Sep 13, 2009 | Whirlpool ES5FHAXS Side by Side...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Frame where door seals is very hot
Fan should be running when compressor and fan in refrig. is running... replace condenser fan, compressor will over heat with out fan running, and refrig. cant get rid of the heat in pulls out of freezer.
Sep 12, 2007 | Maytag MZD2752G Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
97 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
