Question about Olympus Camedia C-700 Ultra Zoom Digital Camera
I put brand new double A batteries in and the camera works for awhile and then loses power
  • 906 Answers
Link
Above is the link leading to your camera manual, kindly browse for some helpful tip. Make sure that we are using the correct battery as there some battery is not compatible to your camera. --see page 2 of 2 for more details.
Thank you
Posted on Aug 04, 2010
Casio Esilim EX-zs10
If it is brand new and any fault is excluded..than the batteries are the only one to blame ...Check again to be sure you inserted them well and in the right position ..and also if you do not use rechargeable ..use only high quality ones..cause some batteries on the market do not have the correct amperage and will not power the camera ..
Also pay attention cause some cameras have a double power source ..and can be powered from an adapter...so ..they have a button to switch mode...This can be the case for you too ..
Nov 15, 2011 | Casio Cameras
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look this..click here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
My Kodak EasyShare C813 camera no longer powers on. Replaced the batteries. Double-checked the connections inside and appear to be fine. Any suggestions to further troubleshoot? Thank you, Green Bay
Have you tried changing the brand of battery? I find mine is incredibly finicky about what make of battery it will accept, especially as it gets older and the contacts on the battery-door lose their springiness. It's to do with the shape of the contact on the minus end of the battery. It will work with B&Q batteries because they have a wide, flat, slightly raised metal cap on the minus end, but it won't work with e.g. Eveready because their minus end doesn't stand up as high and has grooves running round it, which cause the battery-door contact not to - not to make contact, that is.
Even if you're using a classy rechargeable battery, if the minus end doesn't stick up a bit it may not work once the battery door's got a bit worn.
Dec 29, 2010 | Kodak Easyshare C813 Digital Camera
I put brand new double AA batteries into my camera and it still is not turning on , how do i get the camera to work?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 14, 2010 | Kodak Easyshare C813 Digital Camera
Power won't come on
You need to take your brand new camera back. You are not supposed to fix a new camera...you're supposed to enjoy it!
May 19, 2010 | Sanyo Xacti VPC-S770 Digital Camera
My disney camera pix wont turn on
take it back, as it will be under guarantee
Dec 20, 2009 | Disney Pix Micro Digital Camera
I have a samsung digimax A402 camera. I have never had a problem with it powering on until now. I have placed brand new double A batteries and when I press the power button on the camera the screen tells...
My camera did exactly the same thing. I found that there was a minute trace of corrosion on one of the battery conections inside the body of the camera. After cleaning up the contacts to remove the corrosion the camera powered up without fault. It did take some time to get it right.
Nov 01, 2009 | Samsung Digimax A402 Digital Camera
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Battery Problems
I had problem with the "brand new" battereis that came with camera (date on batteries was thru 2014) ... after 2 or 3 pictures ... camera would not work. I replaced with fresh batteries ... works great now. I checked voltage on shipped batteries (that came with camera) ... was about 1.3 volts ... new battereis should be 1.55+ volts. This suggests that shipped "brand new| batteries ... are not "brand new". I called Polaroid .. best I got was "sorry" ... and "call Duracell".
Sep 04, 2007 | Polaroid I533P Digital Camera
Olympus Camedia C-700 Ultra Zoom Digital Camera Logo
19 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
