Question about Dometic Rooftop RV Air Conditioner
We have to replace a rooftop RV DUO Therm ML #57912.622c1 PD#991731647 SL #94932701 the inside ML #3106515.004. Do you know which DUO Therm product to use?
  • 230 Answers
SOURCE: DUO THERM Model 57915.622 runs and cools fine, but why does it drip water inside on the floor?
I am not en expert at RV A/C units. I have worked on a couple before. There should be a reservoir somewhere under the evaporator coil(looks kind of like a radiator in a car but much smaller). It should have a hose or something to drain it away from the a/c unit. These very often become plugged on any kind of A/C unit. However if you choose to do this on your own, you will have to climb on top of the RV and remove the cover from the a/c unit to do this. It might be safer to take it to an RV repair shop.
Posted on Jun 16, 2008
motor1258
  • 6674 Answers
SOURCE: Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Posted on Aug 14, 2008
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Posted on May 11, 2009
  • 534 Answers
SOURCE: my dometic duo therm brisk air RV a/c unit is not cooling the RV
clicking sound could be thermal overload on the compressor. If the compressor has gone out the unit will not cool the clicking sound is possibly the compressor trying to reset but if the compressor has "gone to ground" (winding burnt out) you will need to have the compressor replaced. Good luck on your repairs hope this helped some
Dave
Posted on Oct 27, 2009
motor1258
  • 6674 Answers
SOURCE: Front AC unit will not turn on
The clicking tells me the AC(hydro) power has been turned off to it. Check all breakers, and make sure if you have another switch on wall, to change from front, to back, or to both, that it is in proper position.
Posted on Apr 18, 2010
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
Duo-therm 610015-305 does nothing
check thermostat if ok possible board
May 28, 2010 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
Real unit won't come on
Visit www.bcaparts.com
Apr 27, 2009 | Heating & Cooling
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
333 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
