Question about Philips PLO127C 27" TV
PHILIPS MODEL PLO127/C321 POWERS UP AND THEN SHUTS OFF, WILL POWER BACK ON WITH CHANNEL BUTTON OR POWER BUTTON, BUT THEN SHUTS OFF AGAIN.
  • 4,102 Answers
Hi, this is a common problem with this type of telly what you find happens is that over time the solder joints on the circuit board become dry and brittle and crack, then what happens is when you switch the telly on the solder joints heat up and this then cause the connection to be lost so it switches the telly off, then once its off the solder cools down and connects properly again and this is why the telly comes back on.
now the only way of solving this problem is to go over every single solder point on the circuit board and re-solder every single solder you find.
how ever this is very time consuming and without having the correct tools such as a really fine soldering iron then the job is not worth doing as you would cause more harm than good.
this isnt something you can do if you have never done this before as certain parts of the telly will remain live up 48 hours after you have unplugged from mains and the volts inside are 10 times higher that your mains voltage so i cant advise you on taking the telly apart to re-solder all the solder joints.
you could pay some one but with the age of the telly it just would not be financially worth doing
let me know how you get on or if you need further assistance ok
Posted on Aug 04, 2010
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I cannot auto program tv
Only a universal remote of Philips has the 2 buttons to use the autoprogram,all other won't work.
Aug 29, 2009 | Televison & Video
Philips 14inch color power problem
Take it back where you bought it.If its still under warranty, they'll work on it.If its not,they'll still advise.Hope that helps!
Jan 11, 2018 | Philips 14PT1686 14" TV
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Loses power after (10 seconds) then shuts off
Sounds like a bad capacitor in power supply.
Jan 05, 2008 | Philips FWC550 Shelf System
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Philips PLO127C 27" TV Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
