Question about HP Media Center PC 854n (DB288A#ABA) PC Desktop
How do I remove the hard drive from the computer tower?
  • HP Master
  • 5,660 Answers
1st) HP Support > Removing and Installing Parts > HP Media Center 845n Desktop PC > How to > Installing or Replacing a Harddrive,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03429&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=306210&lang=en
2nd) HP Support > HP Media Center 845n Desktop PC > Manuals,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&docname=bph03429&product=306210&lang=en&
Left-click on -
HP Media Center Desktop PC's - (English) Hardware User Guide
(2.79M)
This is a PDF file download.
After you click ON the file name, it may take a few seconds before you see the first page.
It will take additional time for the file to fully download.
Let the file fully download before looking through it.
At the top of the PDF file is the page number box. It is to the Right of the blue down arrow.
Put your mouse cursor in the page number box.
Left-click once. Type 54, then press the Enter key.
(Fast way to get to Page 54)
Page 54 illustrates and details how to remove the Side Panel of your computer.
Page 60 starts detailing replacing drives, such as the Harddrive.
If you have trouble downloading, or cannot download, please state so in a Comment, and I will lead you step by step.
BEFORE you start!
Follow Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
{Motherboard, Ram Memory, Processor, just to name a few}
Computer unplugged from power, working on a table, computer case open; TOUCH the metal frame of the open computer case, BEFORE you reach inside.
This action will relieve your body of Static.
Should you get up, and walk away in the middle of working on your computer, upon your return be SURE to touch the metal case again.
Better alternative is to buy, and wear an ESD wrist strap, and connect the alligator clip to the metal frame of the open computer case. (Unplugged from power)
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
Computer off, and unplugged from power, work on a table.
Suggest you unplug all cables to the computer tower.
After you remove the Side Panel, suggest you lay the computer on a towel, on the table, computer case side open, facing up.
Makes it much easier to access the internal parts of the computer.
May I ask why you are replacing the Harddrive?
(Post back in a Comment)
Posted on Aug 05, 2010
  • 86 Answers
First take both sides off tower then remove the screws holding the hard drive and then unplug wires and cables in the back of hard drive and pull out the back of the hard drive bay. Please leave feedback.
Posted on Aug 04, 2010
How to Replace a Hard Drive in a Dell Computer Tower?
You need the model of the Tower to be more specific but here is the general instructions:
  1. Locate how to OPEN the Tower and search for a drive that looks like photo
  2. Unplug the cables
  3. Note if you are replacing the drive because it's damaged you may have to order the Operating Disks from the Manufacture if they still offer it.
  4. Or just start fresh and install an operating system find all the drivers on your own.
Oct 18, 2016 | Computers & Internet
Replace hdd
turn off the computer and unplug from wall
open the case/tower
remove wires from hard drive
remove screws from hard drive
remove hard drive and replace with new hard drive
replace screws
replace wires
close up the case
turn on the computer
Does that help?
Dec 27, 2012 | Computers & Internet
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
My p c tower was turned over now it will not work
First check your cables. Are all the internal cables tight (especially the ones connected to the hard drive)? If this computer has SATA connections, try moving the SATA connector to a different port on the computer. If all of these fail, try a different cable (a new one or removed the one from the optical (DVD) drive if it is the same as the hard drive). If this fails it is more than likely you have had a hard drive crash and will have to purchase a new hard drive. Keep in mind the new hard drive will be completely blank. You will have to reinstall your OS and software.
Jun 27, 2012 | Dell Computers & Internet
How do you remove the hard drive from a acer aspire tower T135
If you are looking at the front of the computer case, you will need to remove the cover on the left hand side of the computer case. There should be two screws holding it in place, located on the back of the tower. Once you have remove the screws and cover, the hard drive will be accessible. Simply disconnect the cables to the hard drive and remove the screws holding it in place.
Mar 05, 2011 | Acer Aspire T135 PC Desktop
I HAVE A COMPUTER TOWER THAT THE HARD DRIVE NO LONGER WORKS. A CO WORKER WOULD LIKE TO HAVE THE TOWER AND PUT IN ANOTHER HARD DRIVE. MY QUESTION IS IS THERE ANY THING STORED IN THE COMPUTER OTHER THAN WHAT...
Only a hard drive can contain the data. Other storage mediums are CD, USB flash drive and cards. If your system has any of these, you will easily spot and remove them.
Turning to the hard drive, a computer can have more than one installed so be sure to remove each one before giving it to the other person. No hard drive means NO information stored so be assured.
Oct 06, 2010 | Computers & Internet
How do I get the hard drive out
1 Unplug the computer. As a safety precaution the hard drive removal should not be attempted while the computer is still plugged into the house current.
2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
4 Remove the metal housing. This should be as simple as removing a few screws.
5
Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQCfJhS
  • Step 6 Unscrew anything that is still holding the hard drive in place and then pull the hard drive unit out of the computer. Now you can externally hook the hard drive to another computer to double check the data base. For this you will need an external holder, which you can purchase for $25 to $50 at your local computer store. Or you can add the hard drive unit to the inside of another computer tower.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ9MXYe
  • Step 5 Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ5WTOQ
  • Step 4 Remove the metal housing. This should be as simple as removing a few screws.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ1AnQp
  • Step 3 Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPuIEwv
  • Step 2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPnVKmo
    Jun 14, 2010 | Sony VAIO PCV-V200G PC Desktop
    2000 pc tower , how to remove hard drive
    1. Remove a side panel from the computer tower. http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
    2. Hard drive removal: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm Look down to the Hard Drive section of this link and you should find some detailed instructions.
    You will probably just need a phillips screwdriver to get the job done. Maybe a pair of small pliers depending on how tight the cables are connected. The amount of finesse you use is dependent upon if you want to reuse the drive or computer.
    Dec 22, 2009 | Dell Dimension 2400 PC Desktop
    Need to replace the hard drive
    Very easy to do. You will need an antistatic wrist strap. Unscrew the screw/thumb screws on the side of the case which slides off. slide the case door off, connect your anti static wrist strap to you and a metal part of the case, to ensure you are grounded and don't fry any parts. Check what sort of hard disk your motherboard supports, it could be IDE or Sata. Older ones use IDE. Get a hard disc to match and plug it in where your old hard drive was. The hard drive is probably held in by clips or screws. remove them and place the new hard drive in the hard drive bays. Wire it up. You will need to install an operating system on your new hard drive. This can be done by getting a windows boot cd, entering the bios on startup by hitting the delete or f12 key/ the specified key. Then in the bios go to boot device priority set it to CD. Then reboot and it will install it on your new hard drive. Hope that helps.
    Aug 16, 2009 | Dell Dimension 2300 PC Desktop
    Want to remove my hard drive before I recycle my computer
    Open the two sides . Remove the wiring frm the hard driver. Remove the hard drive from the cage.
    Apr 04, 2009 | Gateway GT5220 PC Desktop
    HP Media Center PC 854n (DB288A#ABA) PC Desktop Logo
    444 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
