Question about Baby Lock Sewing Machines
I have a baby lock professional. I keep getting a wiper error...
Oiling a professional 600 baby lock
Follow the instructions in the owner's manual.
Nov 07, 2017 | Baby Lock Sewing Machines
How to clean wiper sensor on enterprise
Cutter blade needs replacement. Sensor is likely fine and is not located in the bobbin case area.
Sensor is telling you there is a cutter error. More than likely need a new cutter. Easy enough.
Cheers,
Kelly
San Diego, CA
May 09, 2014 | Baby Lock Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Check if thread is entangled, needle is bent
The machine act's as if the motor gets hot and quit's. Once it cool's off, it will work again.
Apr 10, 2008 | Baby Lock Ellure
Sewing Machines Logo
311 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
