Question about Nakajima AE-830 Typewriter
My typewriter keys are not printing what I've typed. How do I reset the keyboard?
  • Nakajima Master
  • 3,594 Answers
The most likely is that the pitch selector slide switch is in PS move it to 10 or 12. If it's in 10 or 12 dlide it up and down a few times the do get dirty.
DickyO
Posted on Aug 04, 2010
I cannot type numbers? how do i reset or what keys should i use so i can type numbers/figures?
the numbers should print just by hitting the key, just like the letters. if the keys are just dead, you may have a bad keyboard or main circuit board. take it to a repairman or get a new machine.
Mar 21, 2011 | Brother GX-6750 Typewriter
Typewriter keys malfunctionE
Al these keys are at the right side of the keyboard andwould seem to indicate a broken track on the keyboard printed circuit board. It is repairable with a soldering iron and great care.
Apr 13, 2010 | Smith Corona Wordsmith 200 Typewriter
How do I memorize an address on this typewriter I need to memorize a sender and a send to address on a fedex form
If this is a WW30 on the L. side of the keyboard are three keys store, play and delete. To store hold the store key and type an address
01 - 99, release store, type info. press store again. To print it hold print type address release print, delete works the same way.
DickyO
Nov 04, 2009 | IBM Wheelwriter 30 Typewriter
Keys don't match what types. Letters type other letters.
Check the connectors from thr PC board to the keyboard, if they are OK tren try this hold the code key press and release the "L" key type 001 release thecode key. If this works you need a keyboard to repair it'
DickyO
Jan 24, 2009 | IBM 3500 Typewriter
Strange letters
Sounds more like the keyboard is going bad. If the printwheel was working fine before, replacing it won't fix this kind of problem.
Also check to see if the light besides " Lang", on the right of the keyboard is lit. If it is hold down the CODE key and hit the key with Lang printed on it. I think its the "L" key.
Another possibility is the keyboard is going bad.
Oct 28, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark 1500 typeover
There are a few possibilities, first check to see if it is in the language mode, light on the rt. side code "L" will get you out of it. If that is OK the keyboard may be selecting the wrong keyboard. Press and hold code key, press and release the "L" key, type 001, release the code key. If this solves the problem. check the keyboard connectors. If they seem to be fully plugged in you will need a keyboard.
DickyO
Sep 29, 2008 | Lexmark Wheelwriter 1500 Typewriter
WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Nakajima AE-830 Typewriter Logo
76 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
